Question about Electrical Supplies
I need instructions to programe my timer its 600 wat 120 volts used for light its not a digital timer
  • 760 Answers
You need to provide a manufacturer and model number.
Posted on Aug 03, 2010
How do I wire GE# 15351 24hr mechanical timer switch for 110 volt outdoor landscape lights
15351 is 240 Volt timer... requires 240 Volt to run clock motor.
You need a neutral wire to connect 120 Volt lights.
15351 has same wiring as Tork 1104
http://waterheatertimer.org/images/Tork-1104-wired-to-control-120.jpg
http://waterheatertimer.org/Basic-house-wiring.html#basic-wire
Gene
Sep 26, 2014 | Electrical Supplies
How to connect my well pump to timer
T8845PV has 120 volt input.... but 24Volt output,
You can use 24 volt to control contactor that can be used to switch 120-240 volt pump
Wiring on following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Dec 02, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
Malibu ML600TW. When I bought my home, one loop with 160 watts of lights has melted the 12 ga low voltage wire completely (looks like it was in a fire) for about 3 linear feet. How can this be possible...
You Tube has a plethora of videos on how to start a fire with a single AA battery.
The low volt power packs put out 12 volts AC, so polarity does not matter as far as the _operation_ of the lights. Polarity _is_ a safety concern only in higher voltages and AC systems that are grounded, such as 120 volts, but still doesn't affect the operation of equipment. Best wiring practice is to follow polarity, even on low volt equipment (
This is more noticeable in an ordinary table lamp. The identified wire (the one with ridges) is connected to the screw shell of the socket. That way people don't get shocked when screwing in a light bulb, thus, _not_ following polarity can present a 120 volt shock hazard just with a common table lamp. 120 volts AC kills more people in the USA than any other voltage simply because it is very common and quite often disrespected.
Yes, the old puncture sites need to be sealed. If you have UL listed low volt cable, it is designed to self-seal when the light is removed from the run. However, as the cable ages this self-sealing feature doesn't always function as intended, especially when cold. This is a possible reason why your cable shorted out and melted. If you want to seal the puncture sites on older cable use a product such as this:
http://www.summitsource.com/product_info.php?ref=1&products_id=9976
It's readily available at most hardware stores in the electrical department.
Dec 23, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Tork 1104 is wired 120 vac. hot wire connected to L with jumper wire to 1.hot wire for outdoor lights connected to X. nuetral wires are wire nutted together. not connected to timer. clock not working....
The clock isn't working because the Tork 1104 clock motor requires 240 volts. Jumping the 120 volts over from terminal L to terminal 1 doesn't make it 240 volts. You need another 120 volt leg (180 degrees out of phase) to do that. The Tork 1103 timer is what you need, or change the 1104 clock motor to a 120 volt.
Dec 16, 2010 | Hardware & Accessories
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
http://waterheatertimer.org/Paragon-timers-and-manuals.html
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Can I use this timer, using only 120 vac to supply a 120 to 12 vac transformer?
no this timer is rated for 240 volts so therfore the clock motor is 240 volts. You will need to purchase a 120 volt clock Good luck!
Sep 11, 2010 | Intermatic Electric Water Heater Timer...
Where you connect the electrical cord from a fount into the timer
The Malibu ML200RT is intended to operate _12_ volt AC (low voltage) lighting _only_.
Assuming your fountain pump is 120 volts, the needed set up would be to supply 120 volt circuit to an Intermatic T101 timer (or similar timer), then connect a GFCI receptacle to the load side of the timer. You could then plug your fountain pump into the now timer controlled GFCI receptacle.
You can use the same 120 volt circuit that supplies the ML200RT transformer.
Mar 27, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Clock doesn't work
The wiring diagram for that timer is somewhat misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt lighting or other load):
Connect the incoming power (line) black wire to terminal # 3. Connect the incoming (neutral) white wire to terminal "A".
Connect the outgoing (load) black wire to terminal # 4.
Connect the outgoing (neutral) white wire to terminal "A".
Mar 08, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Electrical Supplies Logo
47 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
