Question about Ricoh Aficio 150 Copier
Background on copies, possible dirty charge roller , I cleaned all optics is there an adjustment to perform to help eliviate this background
  • 1,219 Answers
yes it could be chatge rollers fault, but how many copies does developer have? I would clean the charge roller with water, dry it, and change the developer. On these digital machine, when you have backround wich is dark, these means that developer is worn out and you need to change it and clean developer cylindar. When the optics is dirty the image will be light, not dark!!!!! Only on analog copiers when optics is dirty the copy is dark, and when the developer is worned out the copy is light!!!!
Posted on Aug 04, 2010
Replace photo conductor
Charge roller and charge roller brush must be cleaned and the cleaning blade should also be cleaned. I the copy was made through the doc feeder then your optics are dirty. Take a damp cloth and clean the slit glass and exposure glass.
Jan 24, 2014 | Gestetner DSm415 All-In-One Laser Printer
How to rest toner from black background
If the copy is dirty background first clean the optical parts component,mirror,lamp,charge corona,transfer unit.If it is OK verify the imaging unit developer and drum,if necessary change it.
Nov 30, 2013 | Konica Minolta Genuine Di181 Di-181 Ep1085...
How to stop backgrounds being printed when i copy something
The optics are dirty.Use a flash light and look at the optics on the printer.I'm sure you will see their dirty.Remove glass ,Clean the mirrors in the scanner cavity with a moist cloth.Don't scratch or press to hard the mirrors are brittle.
Apr 09, 2013 | Epson Stylus CX9400 Photo Printer
Fuser problems
Fuser not cause light copy.If fuser problem the fuser unit not fixing the toner to paper (not fixing image).Light copies :dirty optical parts,Organic Photo Conductor drum,charge roller or charge corona wires or charge corona grid dirty,transfer/separator corona wires dirty.
Aug 13, 2012 | Office Equipment & Supplies
Paper not clean when printing/copying How do I
first the paper can be dirty in a lot of ways...
i.e.
If you have dark "background"or small black dots, the problem is in developer and it need's to be replaced, or cleaning blade or drum.
If you have streaks on copy, the problem can be in drum and cleaning blade or fixing roller.
If the copy is too light, the problem can be in dirty optics or bad transfer corona.
There can be a lot of things... better call service for preventive maintenace, they will change all that is needed according the number of copies that machine has.
Hope that helps!
Sep 01, 2011 | Toshiba E-Studio167 Copier
My copies comes out faintly. pls wat is/ are the cause(s) ?
the light copies on these machine can be result of dirty optics. On digital machine when the optics are dirty the copy is light.
You should remove copy glass and clean the lenses and mirrors and glass with glass cleaner and polish it verry well.
Also the problem can be dirty laser unit.Worn developer, worn drum, charge roller,...
Hope that helps!
Aug 24, 2010 | Ricoh Aficio 1035 Copier
I have a savin 2522 and it has a few lines running down my copies
few fine lines is due dirty optics mirrors and lamp, and it may also came from dirty charge rollers due to dirty/worn out charge roller cleaner, worn out cleaning blade and seal blade. to check this, clean/wipe off toner or dirt from charge roller with cloth wet from alcohol or water. then run some test copy.
Mar 03, 2010 | Savin Office Equipment & Supplies
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Produce a dirty copies
Sound like the machine needs a service, The Optics should be cleaned, and adjusted, machine cavity vacuumed out, rollers and belts cleaned, paper feed and fuser rollers inspected. drum and developer checked. Etc, Etc. Once this is done, the copies should be as good as new.
If you need more information, please contact us.
Hope this is of some help.
Ed
May 19, 2009 | Ricoh FT5832 Copier
Black lines on copies
Have you cleaned the optical path and the laser cover glass? Remove the glass and clean all the mirrors with a soft lint free cloth. Do not use and sprays or cleaners, just a dry cloth. Clean the scanner bed and the glass for the ADF if it has one.
Sep 14, 2008 | Ricoh Aficio 2018D All-In-One Laser...
287 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
