Question about HP Photosmart C6180 All-In-One InkJet Printer
HP photosmart c6180 all in one printer error message of 0xc19a0035, ink system has failed. unable to copy, receive faxes, or print. what can i do to fix it?
  • HP Master
  • 1,684 Answers
The "Ink System Failure" error is caused by air in the ink fed tubes. We have a step by step guide to perform a ink purge on the printer posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ Following this procedure should get your printer back running in about 10 minutes.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Aug 03, 2010
2 Suggested Answers
  • 100 Answers
SOURCE: My HP photosmart c6180 all
The Ink System Failure message (0xc19a0035) on my C6180 were early symptoms that progressed continuous power cycling. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these. here is a
Posted on Sep 28, 2010
Ink system failed???unable to print,copy,recieve faxes
Hello
Have a look at the link below, it should assist you in solving your problem.
http://h30434.www3.hp.com/t5/Other-printing-questions/Ink-system-failed-Error-Oxc18a0101-on-photosmart-D7160/m-p/14911
Nov 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
I use a HP photosmart all in one printer 6100 and i have an error message "ink system has failed" I am unable to print, copy of fax
Several HP all in one owners have had similar problems. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to your HP 6100 printer. acca299.jpg
Oct 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
I received a message on my printer. it reads Ink systm has failed. unable to copy receive faxes or print. Error 0xc19a0035. What does it mean and how can i remedy it.
You likely have a few failed capacitors on your printer's logic board. I have a HP C6180 all in one printer that started displaying this exact message. Powering off then on again clears the error and you can operate as normal for a few minutes to hours until the error re-appears. I suspect your printer will eventually power off then on by iteslf every 15 seconds or so, making the printer unusable. Take the logic board cover off (on the C6180 is is on the right end of the printer), remove the logic board and look for failed capacitors (they will be puffed on the top (see image). If this is the case, you will have to have them replaced (easily done with a soldering pen). The replacementparts are inexpensive (less than $1.00.
Sep 19, 2010 | HP Office Equipment & Supplies
My HP photosmart c6180 all in one printer is giving me an error message of 0xc19a0035, ink system has failed. unable to copy, receive faxes, or print. What do I do?
Aug 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
Help! -- My printer is displaying the following message: "ink system has failed. Unable to copy receive faxes or print. Refer to printer documentation. 0xc19a0035
This same error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Jun 30, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C7280 Ink System Failure
Contact HP for Care at 1-800-585-2494 Toll Free
Oct 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,175 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
