Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
Spark plug gap, Poulan chain saw ? - Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
    Brigadier General:
  • 3,301 Answers
0.025
Posted on Aug 03, 2010
Spark plug gap
.025 is the gap,switch to NGK brand,they are better,Autozone has the conversion.Yours is a CJ7Y ,Champion.
Feb 09, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the gap setting between the ignition module and the flywheel? What is the spark plug gap?
Unsure about your first question as I have had no problems with the ignition module or flywheel as of yet. However the spark plug gap is 0.025 inch
Oct 09, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Proper spark plug gap for poulan chain saws
I believe the proper spark plug gap for poulan chainsaws is .025-inch. That goes for all units.
Aug 22, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a poulan pp4218avhd chain saw that won't sart. I have cleaned the spark arrestor & the air filter. I have replaced the spark plug with a correct gap and checked that it is getting a spark. I...
I have this saw and really like it. Does the the primer seem to work? Most problems on these saws can be traced back to cracked fuel lines. Either tank to primer, primer to carb, or carb return back to tank. I would recommend it the saw it more than 3 years old to replace all the fuel lines. Total cost about $5. Buy your fuel line at Ace Hardware.
May 05, 2010 | Poulan PP4218AV 18" Chain Saw
Doesn't want to start. Replace carb and ran for few seconds, Make you think that it is not getting gas, but pouring gas into spark plug does not help and drying spark plug dose not help. Spark appears...
The spark should be blue and snappy. Try a new plug--any help? If not, it may need a new ignition module. Check the flywheel magnets--they should be quite strong. The module gap with the magnets underneath the poles should be about business card thickness. Check the air cleaner and muffler for plugging. Hope this gets it running!
Apr 07, 2010 | Poulan 1630 16" Chain Saw
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
1,243 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
