Question about Brother MFC-8440 All-In-One Laser Printer
I have put in a brand new drum and it still states drum life at end. What do I need to do?
  • 268 Answers
With the front cover open, press clear/back., press 1 and when the LCD shows accepted, close the front cover and you should be all set.
I hope this helps you..
Posted on Aug 03, 2010
Just replaced drum and says "Toner Life End" but cartridge is almost brand new and high yield (I don't print that much).
Almost brand new means what???. Then replace the toner cartridge which is different then the drum unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 12, 2015 | Office Equipment & Supplies
In the display is the text "drum end " is there a problem with my printer
No. It is common that the drum will reach the end of life at some point. You MIGHT (I dont know if you can for this model or not. I can not find any documents stating that you could or could not) be able to clean the drum. I suggest to contact Konica Minolta if that is possible. If not you will have to purchase a new drum that will work for your model.
I have provided a link below to the supplies for your model from the manufacture.
http://printer.konicaminolta.com/Canada/products/mfp/mc2490MF/supplies.asp
Dec 17, 2012 | Konica Minolta magicolor 2490MF Laser...
A user has to keep pressing the button to keep it printing and screen states DRUM LIFE ENDS SOON. . She just had a new Drum installed
Just do this to reset the drum life counter since you just install a new one. Ive had this issue with multiple brothers around here on multiple parts ie.... drum, belt, toners.
  1. Press the or - button to choose "Machine Info".
  2. Press OK to proceed to the next menu level, and then press the or - button to choose
    "Reset Parts Life".
  3. Press OK, and then press the button to choose ("Reset Drum").
  4. Press OK two times.
Aug 06, 2010 | Brother HL-4040CN Laser Printer
Drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Apr 19, 2010 | Brother MFC-8860DN Printer
I have a brothers copier DCP 8060 and it has a message in the lcd window stating drum near end. What is this...is this is different than the toner cartridge?
The drum unit will wear out and need replacing. The toner cartridge clips into the Drum Unit.
If you print out the system setting report, it usually shows a bar graph with drum life indicated as a percentage.
Dec 08, 2009 | Brother Office Equipment & Supplies
Reset the drum counter on Brother MFC-9840CDW
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Jun 27, 2009 | Brother MFC-9840CDW Laser Printer
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Toner life end
Try this:
Open the cover, leaving everything inside. Press Options, then *00 to reset the fax.
If that doesn't work:
Open the front cover and remove the cartridge and drum. Turn off the fax. On the right-hand side of the cartridge, there is a round hole that is covered with a clear plastic or glass. Cover that hole up with tape, put the cartridge back in the drum, and put them back into the fax, and turn it back on.
Dec 05, 2008 | Brother IntelliFax-2820 Laser Fax
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
Drum End of Life
Unfortunately the manufacture has you over a barrel.
Have you contacted Minolta?
Ask for technical support sry not much help.
Nov 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
Brother MFC-8440 All-In-One Laser Printer Logo
217 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
