Question about Intel D945GCL Motherboard
Cpu shut down due to overheating - Intel D945GCL Motherboard
  • 358 Answers
To Resolve this Problem . You have to go ta a computer peripheral shop and buy a Heat Sink Flux . Which help CPU to keep cool. Then apply this paste on processor Surface . Then again lock the fan and start your computer.
It Will Work Fine 100 percent Guaranteed
Posted on Jan 28, 2011
Windows shuts down unexpectedly blue screen
It'll be probably due to the overheating of your cpu. Just check whether all system fans if your cpu are working.. If it is check the moulding of fan to the motberboard.
Apr 26, 2017 | Blue Computers & Internet
My computer will keep cutting off it mainly do it when im on netflix i thinking it got somethin to do with my shockwave
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 05, 2013 | Toshiba Computers & Internet
My laptop's fan isn't working so my laptop shuts down on its own every nw and then which i guess is due to overheating.what should i do to repair this problem?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 19, 2012 | Acer Aspire 3680 Laptop
Auto shut down occurs due to overheating
you might want to replace the CPU fan and re apply a thermal paste between your processor and heatsink. Make sure the heatsink and CPU fan is securely in place to avoid thermal problems
Mar 13, 2010 | Computers & Internet
Computor shuts down. screen goes to black. turn back on and get siren sound and screen says shut down due to thermal event. hit F4 to resume. had same problem a couple years ago and they replaced fan
try applying new cooling pest between cpu heatsink and cpu. Heat from cpu surface should be quickly transferred to heat sink. Either coolent problem or heatsink doesnot properly fit on cpu. But be carefull, you need an 'EXPERT' to do this, or you end up damaging everything.
Jul 30, 2009 | Computers & Internet
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
HP desktop that shuts down after 15min.
Usually when this happens it is due to the thermal monitor in the cpu telling the system it is overheating. This can be caused by a weak or worn out cpu heatsink/fan. I would recommend replacing the heatsink/fan assembly with a new one making sure to use a good quality thermal grease between the heatsink & cpu. Reassemble and see if that fixes the problem. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Computers & Internet
Hello.., i m using asus K8VMX motherboard...problem is it is shutting down
Yes, It most likely is a overheating issue.. The motherboard has a feature built-in which monitors CPU temperature and shuts down the system as soon as CPU temps exceed manufacturer's limit.. Kindly look into reseating the Heatsink Fan (HSF) also make sure the base of it that contacts the CPU is Clean so proper contact area can be achieved, also apply some thermal paste if handy or available.. Also take a note if the Heatsink Fan is connected and functioning properly..
Mar 05, 2008 | ASUS K8V-MX Motherboard
PC gets shut down
this means that it is overheating. you can do many things here. 1. take off the CPU cooler, and reapply some heatsync and see if that fixes the problem. 2. buy a larger, or more efficient CPU cooler, newegg.com is a great place to find good parts that are cheap and come with customer reviews already. 3. change the settings in your bios to allow the CPU to become warmer (do not go above 75 degrees) without shutdown or alarm.
Jan 06, 2008 | Audio Players & Recorders
CPU fan not working
you need to check your power supply if this is okay you need to replace the cpu fan. the cause of shutting down is the overheating of your cpu
Jan 06, 2008 | Acer Veriton 5200D PC Desktop
Intel D945GCL Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
