Question about Motorola Mobility ic502 Cellular Phone
My phone is stuck with the in progress screen and I have no way to get to menu.
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
May 12, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Stuck in Progressive Mode
Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
May 06, 2008 | Dual DWM-3900 System
Magnavox MDV560VR DVD Player Stuck in Progressive Scan
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Mar 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Moto V3i Sending SMS problem
sir first take the back up of ur phone & try with master reset option of ur phone good luck
Oct 19, 2007 | Motorola Mobility RAZR V3i Cellular Phone
MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Apr 29, 2007 | Goldstar GBV241 DVD Player/VCR
DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Motorola Mobility ic502 Cellular Phone Logo
95 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
