Question about General Electric AEE18DM Air Conditioner
Need to replace a 1960s General Electric Thinline through-the-wall air conditioner with a new unit. How do I remove the chassis from the sleeve? Is there an installation manual available for these old models?
  • bob3204 Aug 03, 2010
    The AC unit is NOT an AEE18DM. I don't know what model number it is, and don't think it much matters, and FixYa just stuck this model number on the question for some reason.
Is this one of the big square shaped units? If it is, I think I can help. If it's in a wall, you'll have to take it out. Then remove the screws from the bottom on both sides. The cabinet SHOULD lift off. That's right..... LIFT off.
The chassis WILL NOT slide out from either end. I have one of these that is in a window. It still works. I saw your question and went and took a look at it, and this is how I think it comes out. If you still have the plastic vent grilles that go on the inside over the fan and evaporator, I'd be interested in buying them if you aren't going to keep them, as mine are in bad shape. The one that goes over the evaporator is an off white beige color and has three round vents that can be turned to direct air flow. The piece that goes in front of the fan is a dark brown color. Please let me know if this IS how to remove the chassis, as I may have to do it myself someday. I won't as long as the thing keeps working.
Adam
Posted on Aug 08, 2010
Looking to replace a guasar wall aircondition that fits a sleeve the size of the aircondition was 26 3/4 by width is 25 1/4
Fredrich makes one which may work in sleeve or install a new unit with sleeve and put molding around hole in wall .
Oct 01, 2014 | Quasar HQ2051TH Air Conditioner
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
How much does this unit weigh?
dear sir
AMNA PTC153D35AR AIR CONDITIONER,S SPECIFICATION DATA ARE GIVING BLOW:
Dimensions & Weights Overall Width: 42" Chassis Width: 40" Wall Sleeve Width: 42" Overall Depth excl. Outdoor Grille: 21 1/2" Wall Sleeve Depth: 14 1/8" Overall Height: 16 1/16" Net Weight: 105 lbs. Shipping Weight: 120 lbs
Sep 29, 2010 | Amana PTC153D35AR Central Air Conditioner
Need to remove through wall fedder air conditioner
If it has a sleeve, just remove the front cover and give a little yank on the unit and it will start sliding out of the sleeve. Unplug the unit first, and the unit will slide all of the way out of the sleeve and you can just set it on the floor or wherever.
Jul 06, 2010 | Heating & Cooling
Replacement for Emerson Quiet Kool 12jw42k
Oh yes,there are plenty to choose from,you can go larger,if it is a 220 volt,and get better service,it will cool better,and cost less,on electric.
May 28, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
I have a 27 inch wall sleeve can a 26 inch friedrich unifit work?or do I need a 27 inch unit
the a/c units keep getting smaller, when unit replacement is slightly smaller , the extra space can be filled with a piece of plywood or rigid foam insulation with a thin layer of plywood, any edges seen from inside can be covered with trim, make sure the wood covers entire bottom layer of sleeve to properly support. or just find the larger unit if you can. hope this helps.
Apr 23, 2010 | Fedders A6U14W7B U Chassis...
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Is this the right unit? Can it be used with a sleeve?
If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
Jun 12, 2008 | Heating & Cooling
General Electric AEE18DM Air Conditioner Logo
434 people viewed this question
Top General Electric Heating & Cooling Experts
Bill Long
AJMAL KHAN
Are you a General Electric Heating and Cooling Expert? Answer questions, earn points and help others
