FixYa.com
Tags:
ASUS K8V-SE Deluxe Motherboard
Case swap
posted by pchrist on Apr 25, 2008
I just installed this motherboard into a new case. The corner where the secondary ide slot is gets pretty warm is that normal. Could that be causing it to lock up. I had the unit running with out a case and had no problems. Now it locks up once in a while. It also has very loud humming coming from the speakers. Does anyone know how to get rid of these issues??? Could it be a driver???
Thanks in advance
Pete
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 25, 2008
Not Rated (0)
myob247
Rank:Wiz Wiz
Rating: 84%, 417 votes
Did you put any kind of spacers between the board and the case so that they are not touching? If not the case may be shorting it out.
If it is overheating it could lock up or shut down.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
HI I need driver
mother board: Lite-On NR146... Answer This...
Motherboards
change the start up logo on a...
hi i would like to know how... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
