Question about MSI P6NGM-FD Core 2 Quad Socket 775 1333MHz PC2-6400 Motherboard Retail
MSI P6NGM won't BOOT
I had a wondewrful PC built. It worked well untill...
Here's the specs::
core 2 duo 2.4, 2GB DDR2 ram, 250 WD HD,680 watts PSU, 3 fans: 120 & 2x 80. Last week I turned up fsb so the cpu was running as 2.9. Passed stressed tests. But last night I placed in 4GB of DDR2 ram and it made a loud flatline sound. I was told to put the old ram back in and turn ram down below default of 800mhz. I tried this but it didn't boot. It powers up lighted fans and all but no beep beep it normally makes during the boot cyclce. And ofcourse no display. Can anyone help me cause I'm truly lost?
  • 2 more comments
  • akiloj Apr 27, 2008
    Thanks mike for your comment, but it was the ram. In addition to orthos stress tests for 15 hrs. I also used the PC daily. But once I put in the new 4GB channell of ram I was able to get into bios. I turned the mem spd down. Now the prob is it's not boooting from the HD. It's recog as 1st in the boot sequence but it has parenthesis around it. something about it's disabled. My old HD was 2nd in the boot sequence now it's off the list. I'm not a tech I just have alot of common sense so I figured I can do this by myself. I am so close!!
    If Im able to get into bios do I still need to clear cmos?
    I almnost understand the comment about resetting master/slave issue; however my new HD is sata no master/slave. Besides I took out the power cable for the old HD; and I took out the sata plug in the new HD that's first to boot. But since all of this happened, My old HDD was second to boot which was a master drive. I took out the slave an older optical drive & added a new sata drive. Bios recog the changes.
    OK, I think I may have found the prob::Under ATA devices should raid mode be raid or ide? It's currently raid with sata 1-4 enabled. I made this change late last night when bios was recog the old HD but it was disabled.
    President:
  • 2,351 Answers
You should only hear 1 beep. That 1 beep is power on self test, known as P.O.S.T.
That loud flat line sound (And I'm pretty sure about this), was you're CPU. Just because you ran & passed the stressed test is nothing compared to running the system under load? That's why when you put in you other memory nothing changed. If you hadn’t mentioned you clocked up the FSB I would have come to the same conclusion hearing the loud flat line statement.
Can you test the CPU in another board? That is about the only way to be sure it's not the CPU. Memory does not make that kind of sound. Memory makes short & long beeps.
You can try clearing the cmos/bios by going to pg. 2-18 in you're user manual. This will reset the bios back to default settings & cross you're fingers!
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Posted on Apr 27, 2008
  • 1 more comment
  • Mike Peluso
    Mike Peluso Apr 27, 2008
    How to vote you're expert & also how to repost more questions for same problem or to answer expert's questions.
    Enter FixYa.com site.
    Sign in to your FixYa account.
    Locate My Profile on our FixYa's homepage.
    Under My Problem locate your problem and click on it.
    Add another question to the current post....
  • Mike Peluso
    Hi akiloj,
    No, you do not need to clear the cmos since your in the bios but it can't hurt. I would reset the bios while in the bios. Check the bottom of the bios menu. You can set defaults while in the bios. Than go over the settings & look for & changes that need to be set to enabled. As far as the hard drive not booting up. You counld try disconnecting the slave drive (Power or data cable only). Bios will not see you're slave drive. (I know you took it out of boot order). Reset the pin for the Master drive as a single master/no slave. Boot the system see if windows loads. If it doesn't you can boot to the CD-ROM & repair windows.
    If you decide to repair windows re connect the slave & reset the master's pin to master with a slave. I'm glade you got it to run.
    You did real good. (I'm bad)!
    Keep me posted.
    Good Luck!
    Mike
  • Mike Peluso
    Mike Peluso Apr 28, 2008
    Hi akiloj, setting the to IDE does not mean you're drives will run slower (IDE speed), it means you will not have to see the setup RAID screen. So, yes set RAID function to IDE. My own board is set up the same way.
    Mike
Msi pr200 2 beeps on start
if your device fan works then check its RAM
if long beeps check if the battery is good and your adapter charge it or not
main board
Apr 11, 2014 | MSI PR200-029LA Notebook - Intel Centrino...
..................My system config is : Intel C2D E7500 with 2.93 GHz CPU MOBO is Intel DG41RQ and 2gb DDR2 RAM OS is Windows XP - 32-bit (Service pack 3) .Problem is iwant to buy a new graphics card
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 10, 2013 | Intel DG41RQ Motherboard & Core 2 Duo...
I have dell optiplex 755. Does my system support ati radeon 3650?. Also recommend me any else card which is suitable for my computer
what model is this small form factor ? mini tower?anyhow, here are the things that you may consider .
if its a small form factor unit then you may need to get a video card that is Low Profile
and also consider the power supply :
The ATI Radeon HD 4650 512MB Low Profile PCIe x16 graphics card should work fine with the 275w PSU.
Max power draw is 48 watts
Oct 13, 2012 | Dell Optiplex 755 Minitower Desktop...
Does asus p5n73 am mother board support asus ati radeon HD 6450 graphic card? my smps is 450 watt also let me know which graphic card support my mother board
your power supply is at the edge, so i'd suggest going for 650W power supply. your mainboard will support the graphics card but as i said - you need better PSU
Mar 13, 2012 | ASUS HD 6450 DDR3 PCIE Native HDMI SILENT...
Hello sir, Does NVIDIA 9800 supports my system configuration ----------> intel core 2 duo intel original dg31 motherboard 2 gb RAM ddr2 250 HDD
YES! In fact I have an Intel core 2 duo motherboard and I have an nVidia 9800 video with a 2GB RAM. It works great!
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 22, 2011 | Computers & Internet
Today without any warning, after i started my pc, when it load until the window loading screen, suddenly the screen turn pitch black & a loud continuous beeping sound was started. I tried to trace...
Try it with 1 gb memory if it still beeps, try it on a different slots. if it works with 1gb turn off the pc, slowly add the other rams then test
Aug 23, 2010 | Computers & Internet
Cooler master extreme duo psu + Acer Nvidia MCP73 mobo
No it will not. The motherboard has voltage regulators which correctly distributes voltage through the integrated circuits to the chips/capacitors/etc. that need power. The only reason you would need a stronger PSU with more output wattage would be if you had lots of internal parts that drew a lot of power (such as 4-way SLi cards with power adapters plugged in, sound card, 4 hard drives, 4 optical drives, TV tuner, lots of fans, etc.). A setup like the one I just described would probably need at least a 750 watt PSU. But in any case, you could have a 2000000 watt PSU and it would not fry the board due to the reasons above.
Jan 14, 2010 | Gateway GT5685E Desktop Computer - Intel...
Hi, i just put together 2 ms7380 motherboards, pentium d 945 3.4 ghz 680 watt antec psu galaxy 9500 series video card WD caviar 500gb HD and have tried several 1 and 2 GB ram ddr2 everything turns on and...
Make sure power is connected to video card, Check standoffs, make sure no extras shorting mobo, Make sure video card is plugged in slot properly. Post mobo - cpu - ram - video card out of case. if all ok then mount with proper standoffs.
Nov 20, 2009 | Intel Motherboard
MSI P6NGM Issues
I would put the old ram back in, and then reset the bios by following the instructions in the motherboard manual. (usually with putting a jumper on some pins)
Harris
Apr 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
MSI P6NGM-FD Core 2 Quad Socket 775 1333MHz PC2-6400 Motherboard Retail Logo
1,044 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
