Question about Microsoft Xbox 360 Console
Out of no where i turn on my xbox 360 and there is one red light what does that mean
  • 4 Answers
One red ring of light on the xbox 360 consoles defines, hardware failure.meaning,one of the core components on your xbox 360 simply malfunctioned.The main root of this problem is because of excessive heat that eventually misplace the position of the GPU.However,The said problems can be solve on a DIY(do it yourself) procedure (provided that the xbox 360's warranty no longer exist.if you still had the warranty replacement deal and it's still active,you can send it directly to Microsoft where they will change your unit for free,shipment and couriers fee at your own expense) Okay,you can temporarily fix this problem by X Clamp fix method,where the main idea is to dismantle your xbox,add additional washers to the main frame,re applying of thermal paste and modifying your system with additional fans and bracket.the process is not too long and definitely very reliable.
Posted on Aug 03, 2010
    Scholar:
  • 72 Answers
Microsoft Xbox Support provides a troubleshooting guide on the web:
http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=frls
If the troubleshooting guide does not solve your problem, you will likely need to send the unit in for service.
    Problem Solver:
  • 9 Answers
This is the display chip overheating and to stop this heat you need to use a good guide
that will show you how with household items or you can send it in to get it fixed.
Posted on Aug 29, 2010
4 Suggested Answers
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
SOURCE: The xbox 360 red light flash
turn it on and wrap it with 2 towels for 20 minutes(the idea is to overheat it), then unrap the towels and let it cool down for 20 minutes. Then, walla it works.
Posted on Dec 30, 2007
Filidor
  • 28 Answers
SOURCE: error 4424 on xbox 360 with 3 red lights
No it doesn't mean the console is ****. This could be related to several different issues and hasn't necessarily been pinpointed to one problem in particular. Two of the most common problems are with the x-clamps and cold solder points.
The x-clamps could be putting too much pressure on certain parts of the board now from all the wear of constant heating and cooling. This can be fixed using the X-Clamp fix and is fairly easy with the right tools.
Cold solder points basically means that points in the solder holding the chips on have cracked from rapid heating and cooling. This can be fixed with the simple "towel trick".
I would suggest trying the towel trick first as it is free and the simplest. Next I would suggest the X-Clamp fix. You can find guides to all of these with a simple google search. If neither of these works then it may be time to call for a new xbox, as it usually goes downhill from there. Good Luck!
Posted on Mar 19, 2010
IGOT 3 RINGS OF DETH
Three red lights on the ring of light is an indication of a hardware failure
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 14, 2009 | Microsoft Xbox 360 Console
Red light blinking on front of xbox 360
How many red lights flashed? One, or three?
One means that your harddrive isn't seated correctly.
Three means that your console is more or less screwed, and needs to be repaired by Microsoft.
Apr 10, 2009 | Microsoft Xbox 360 Arcade
Three red lights
Follow this steps:
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow the steps below, Hope this helps
Dont worry shipping and handling will be covered.
Apr 03, 2009 | Microsoft Xbox 360 Elite Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
2 red lights
This problem may occur when the Xbox console is too hot or is overheating. The flashing lights mean that the internal temperature of your Xbox 360 console has exceeded acceptable temperature limits. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot.Verify that your Xbox 360 console has enough ventilation and that the fans are operating. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Microsoft can be contacted by finding the number listed on the back of your video game booklets.
Good Luck to you and Happy Gaming.
Source:
http://support.microsoft.com/kb/907533
Oct 17, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
I get red rings when i turn on my xbox 360
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
X-box 360 wont turn on
If the lights are red, this means that your 360 has had a hardware failure. This failure is also known as the "Red Ring of Death." If you have bought your XBOX 360 with in 3 years of posting this, your will still have free 3 years of warranty from Microsoft. Call them at 1-800-4my-xbox. (1-800-469-9269)
Hope this helps :)
Jan 20, 2008 | Microsoft Xbox 360 Console
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
62 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
