Question about IOGear USB Print Server, 1-Port [ GPSU01 ] (112743) Print Server
My wireless modem Actiontec mi424wr is uable to see the print server GPSU01? What changes do I need to make to the Actiontec mi424 wr wireless modem?
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
Iogear GPSU01 DRIVER FRO WINDOWS 7
Try this it may help.
Download and install XP mode as a virtual machine. Which should solve the all
too often problem related to no being able to find a WIN 7 or 64bit driver.
FREE from Microsoft. I use it and it works great
http://www.microsoft.com/windows/virtual-pc/download.aspx
Selvol
Feb 02, 2012 | IOGear USB Print Server, 1-Port [ GPSU01 ]...
How can I disable my actiontect GT704WGR wireless setting? Verizon personnel has enable the wireless setting of my modem actionteck GT704WGR 2 days ago. Now I would like to disable it because I will use...
you can login to the Actiontec modem by typing the ip address of actiontec modem in the address bar of Internet explorer...
It will open the interface of actiontec modem...
In the Interface of actiontec modem you will have option for wireless...
If you look under wireless setting you will be having the wireless mode as 802.11b/g/n or just B/G/N....
Change this wireless mode to OFF...
Thats it you are done...
By default the ip address of action tec is 192.168.0.1
Dec 13, 2010 | Actiontec Electronics (GT724WGR) Retail...
I have a new HP Pro 8500 Premier. It says I need to open Port 427 to use wireless. How do I do that?
fist try to enter modem config site at 192.168.1.1
admin user: admin
admin pws: password
goto my network
chose the device you wanto to enable
http://portforward.com/english/routers/port_forwarding/Actiontec/MI-424-WR/Echolink.htm
if didnt work cll verizon tech suport
1 866 268 4630 ext 1112 direct line 24 hrs
Apr 17, 2010 | Actiontec GT704WG Wireless Router...
Wireless Internet Issues
USERNAME:admin
PASSWORD:password or password1
That is the default user/pass, if it has been changed from default, you will have to reset the router and then use the defaults I gave.
Mar 31, 2010 | Actiontec Electronics (GT724WGR) Retail...
We are having problems with our wireless internet router. We have the WEP key and the wireless web name. The model is and Actiontec MI424-WR. How do we either figure out the password or how to log-in to...
donot enter http before those numbers...just type that number alone in the browser and log in to router....there below the wireless option you can see the security key for your wireless network....
Mar 31, 2010 | Actiontec Computers & Internet
USB port on Actiontec for shared printer?
There is supposedly a firmware upgrade available that extends the functions of the usb port so the short answer is "maybe"
My best suggestion is to check out the actiontek web site. Also you should try access the setting page (http://192.168.1.1) and see what options are available within the router itself for USB
http://support.actiontec.com/doc_files/MI424WR_Rev._ACD_User_Manual_4.0.16.1.56.0.10.11.3_v6.pdf
Is the user manual
Aug 07, 2009 | Actiontec GT701WG Router (actiongt701wg)
Actiontec router
Move the second camera to just a few feet of the AP. After setup you can move it back out.
Jul 06, 2009 | Linksys Wireless-G WVC54GC Network Camera
Router MI424WR-D
Hi Steven,
You will not be able to setup this printer wirelessly to your router as it is because the printer has no networking capabilities(ethernet or wi-fi). If you want to share the printer throughout the network you need a wireless/wired print server or just enable file and printer sharing on the computer where the lexmark printer is connected the only downside with the second setup is the computer where the printer is connected must stay powered on all the time in order for the rest of the computers ion your network to print compared to the 1st setup with the a print server which is stand alone.
Mar 06, 2008 | Actiontec (5GE583000-01) Router
Open Questions:
Computers & Internet Logo
240 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
