Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Tried the solution by the guru but the tv now keeps turning off
Tried the solution by the guru but the tv now keeps turning itself off after just a couple of seconds and the blinking green light starts again.
  • packydilley Aug 03, 2010
    Tried the suggested solution of volume up and channel down, while tv unplugged and then plugging tv in at the same time. This allowed the tv to turn on for just a few seconds and then the picture went back to black and the green light for power is blinking on and off every second.
  • 53 Answers
SOURCE: No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Posted on Mar 14, 2008
ginko
  • 19396 Answers
SOURCE: Phillips 51in tv rear projection power button blinking green
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
dsacco86
  • 1077 Answers
SOURCE: power light keeps blinking green with no display
I would try leaving the TV unplugged for 30 minutes to let the TV reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
Posted on Sep 14, 2009
bshldn
  • 736 Answers
SOURCE: when i turn on my tv the green power light blinks and the tv does
There is a procedure called and Industry INIT. The reason I cannot post it is that if it is done incorrectly it can wipe the memory of your television. Also if you get a yellow screen versus a red screen versus a green screen there are different steps to peform next. To attempt and Industry INIT you would call 800-237-4277 pressing 1 for each of the prompts. If the Industry INIT fails the representative will direct you to your local service provider. If you were interested in performing the repairs on your own partstore.com has parts.
Posted on May 10, 2010
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
Hello! .. I have a TV Sony KDF-E50A11E ..... At one point, get the following problem - when you turn on, LED blinks in green and then green and red, and after 4-5 seconds turns itself off - relay hear...
How many hours are on the set? It sounds like the lamp is going bad, and won't let the power supply turn it on... Give that a try first and we will go from there. Good luck HDTV GURU JAY
Mar 18, 2011 | Sony KDF-E50A11E TV
Had power outage, then when power back on in house, tv green light keeps blinking even after unplugging and pressing reset button and attempting re turn on. we use a surge protector, tv is 65"...
This is a solution that was previously posted by Fix-Ya Guru Freetek for the exact same TV and same situation:
http://www.fixya.com/support/t2115048-green_timer_light_blinking_tv_turn
Mar 05, 2011 | Mitsubishi Televison & Video
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
TV KEEPS TURNING OFF ITSELF
this sound like your regulator is not working see if the set turns off in white senes if so replace it
Oct 15, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
50 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
