My machine will not rinse or spin but it does agitate.
    Master:
  • 555 Answers
What is the maker & model for this washer?
Posted on Apr 25, 2008
Why does not agitate on rinse cycle
It shouldn't agitate on rinse cycle. ''Quick wash'' is the last type of ''cycle'' you can select that the machine will ''agitate.'' On ''rinse'' cycle, it will fill with water and then simply drain & spin.
May 18, 2015 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Machine now only agitates and no spinning and rinsing
Check the lid switch for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore Washing Machines
My machine loads and agitates, but will not drain, rinse or spin
If this is a top load machine check the lid switch.
If you manually advance the timer to spin, open then close the lid, and get no spin, it is a bad lid switch.
If it does spin, report back for the next step.
Apr 21, 2009 | Kenmore Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washing machine will fill,agitate,but not rinse or spin
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore Washing Machines
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
