Question about Watches
How do I remove the back of my Citizen C480 watch so that I can change the battery?
5 Suggested Answers
SOURCE: removing the back to change battery
I had the same problem.
Remove the watch band.
I had to cut the plastic band away.
The plastic was was easily cut.
The back plate of the watch simply snaps away.
No screws.
There are four corner snaps.
Get under one and the others will pop off.
Posted on Jan 19, 2008
  • 65 Answers
SOURCE: Changed battery(capasitor) in citizen E811m. Watch
I take it this is an Eco-Drive. You must ensure you have the correct replacement cell (cap) and it will need charging. See your instruction manual for details on charging. You can download instrustions from citizens website if you've lost them.
Posted on Jul 24, 2009
SOURCE: How to change to time setting of CITIZEN WATCH CO.
Purchased a Citizen watch and it did not come with an instruction manual. How can I get one?
Posted on Jan 12, 2010
mcdevito75
  • 1970 Answers
SOURCE: Battery change Citizen Promaster Watch Model# C112.
mcdevito75 here, You should be able to get some help online at citizenwatchserv.com in the meantime you can try to press and hold in the MODE button, press and hold it in for a couple of seconds. Also< IO wouldn"t be surprised if the battery has to come out and installed again, same new battery just simply have it taken out and put back in, maybe some sort of re-set. Check out the website, don"t do anything till then.
Posted on Jul 18, 2010
Removed MT516 battery from Citizen 780163 Eco-Drive watch to change battery for wife.. then found out is rechargeable, but didn't realize it has leads welded on & now unsure how to align / position it...
you should use a multi meter, to check where the plus and minus is. to check where the leads go to, put the charger on and check where the plus and minis is coming from.
Never open a watch, if you don't know in advance what you can find. It is to delicate inside, and most of the time you lose the water tights seal.
Mar 03, 2014 | Citizen Watches Eco-Drive Carbon Fiber...
Tutorial on battery change
These Aqualand watches have three separate batteries and are not meant to be changed by anyone but citizen repair person. It is best to send back to ensure it is water proof. It's not real cheap though
Sep 28, 2013 | Citizen Aqualand Duplex JP1074-58E Wrist...
I changed battery in my Citizen ai3730-58l and now I can't set time? Could you send me operator manual please.
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
May 06, 2011 | Citizen AI3730-58L Wrist Watch for Men
Have fitted a new battery but no joy, any tips I can try?
mcdevito75 here, Some quartz watches and I believe Citizen is on of which need the exact factory number battery installed / replaced. if you did use the exact battery number and the new battery is not working, remove the battery and carefully clean the battery contacts with a Q-tip and rubbibg alchohol do not soak the battery contacts just clean them. Also your new battery could be dead, who knows how long it was on the store shelf. Alaso wipe off any oil from your fingers on the new battery before you install it in the watch, make sure the battery is seated correctly in the watch, the back cover may also have to be installed back onto the watch to complete the battery circut for the watch to work. If all this fails you can try to contact Citizen online, Contact CitizenWatch.com and get their recommended battery size for your watch, OR, look for a small watch repair shop in your area. One Last thing, Your Citizen watches Quartz mechanism could also have gone bad, in this case you"ll need a new watch.
Feb 11, 2011 | Citizen Watches
Jul 18, 2010 | Citizen Watches
Hi I have a citizen red devils navihawk world time watch. when i change the battery and everything is change and i can not set it. I also lost my manual book and I would lik to have the imformation set my...
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download.
Mar 19, 2010 | Citizen Blue Angels Skyhawk Watch
I have an old Citizen Aqualand dive watch, "c022-088034 y"- the battery has run out, Citizen report that the part is discontinued (citizen part number 280-5101). Is there a generic battery that...
hi, I'm from Italy and changed the batteries just 2 days ago - theer are three batteries inside this watch - in a normal shop selling citizen watches.....
I think youhave just to change shop....
Aug 19, 2008 | Citizen Watches
Citizen eco drive cell installation
a customer came with a eco drive watch dead. i opened the back and removed the battery. the battery was totally dead i fixed back and kept the watch in sunlight for an hour still it did not work. what could be the reason?
Oct 31, 2007 | Citizen Eco-Drive Silhouette EW869452D...
Watches Logo
148 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
