Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Both of my remotes decided to stop working at the same time I tried to reset and change battery and still dont work. They are less than a year old
  • advojosie Aug 05, 2010
    We have a wireless pad on the outside of the house and that works. Is it on a different board?
    Well we bought new batteries for both and still did not work, so I went and removed batteries from some where else that I was working and put those batteries in my remotes and they worked!! It turns out that the bateries we bought were no good! Thank you so much for all your help
    President:
  • 3,197 Answers
Both remotes quitting at the same time points to the receiver which is part of the logic board. It has failed.
Posted on Aug 03, 2010
  • 3 more comments
  • advojosie Aug 03, 2010
    I figured something has failed! I am trying to find a way to fix it.
  • Don Maggard Aug 03, 2010
    The only fix for a failed logic board is to replace it. There is no schematic available from the manufacturer.
    So all I can do I have to replace both remotes?
  • Don Maggard Aug 05, 2010
    No it is not your remotes that have failed. It is the logic board.
    No it is on the same board but uses a different code. Maybe it would help if you tried programming the remotes. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and hold the button on one of your remotes while you press and immediately release the smart/learn button. See if that changes anything. Otherwise I still think it is your logic board. Make sure the batteries in your remotes are good also.
Neato robot turns on, fires up vacuum/brushes, but won't move - no error messages. What gives?
I have a Neahis to Botvac 85, had also problem, it started up then stopped. It is 2 or 3 years old, don't remember. but it started to ack very strange with the battery. then this start/stop problem came. I ordered a new originial battery and thought it should solve the problem but no it didn't After some time I decided to try again. Started Neato and it stopped after some time, then I wanted to see if the lidar was rotating so I removed the blue cover over the lidar and could see that it was rotating, then I touched it little bit and the neato started and started to clean my floor. so try this.
Sep 12, 2014 | Neato XV-21 Pet & Allergy Automatic Vacuum...
We had this tv for less then a year nd all ov a sudden the remote stops wrking for the tv and we dont know whats wong with it we bought new batteries still doesnt work would u be able to help me out
Take out the batteries clean the - + battery connections with some rubbing alchahol,wait like 20 mins. put batteries back,still have the same problems.Tv is under a year old,tv still under warrenty call the tv company for remote warrenty replacement.
Mar 18, 2011 | Televison & Video
My samsung tv won't turn on , It just started to
Your Samsung LCD TV needs a new power supply. You can obtain one by part number from sites such as shopjimmy.com, discount-merchant.com or tristatemodule.com.
Apr 26, 2010 | Samsung LN46A650 46 in. LCD HDTV
Jeep one year old. Keyless just stopped working. Engine starts for a second then cuts off. Replaced battery in key/remote and still doesn't work. Now alarm sounds if opened with the key the old...
Assuming you have a second key try using that one to deactivate the alarm, if not replace battery in remote. Does lock and unlock work now? you will need to get the remote operational to disengage the security feature that will not allow car to start.
if not disconnect the car battery let sit for 15 min to reset system try again..make sure bettery in remote is installed properly.
Nov 28, 2008 | Jeep Wrangler Cars & Trucks
Keyless Remote, Power Antenna, and Clock problem
have u tried under the dash a black box which is to alarm open it up there will be 2 pins there that u need to bridge with a flat screwdriver at the same time the blinkers should flash then press each of your remotes to programme them hope this helps
May 23, 2008 | 1999 Nissan Maxima
Hunter ceiling fan
Have you contacted Hunter? Have you turned off the wireless internet to see if fans work? You may have to try another internet brand or try moving to another part of the house.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 12, 2007 | Oasis Hunter 54' Ceiling Fan
Microsoft wireless optical mouse
you have two micro switches that wear-out quickly. try going to. Control panel. Click on Devices. Then on Mouse try switching your right button to left button on button options. try hitting restore defaults. Make sur your remote sending unit is plugged in and the lie is on steady. good luck Joe_Rex
Apr 26, 2007 | Microsoft Wireless Optical Mouse
Toshiba TV Remote Control not working
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Jun 27, 2006 | Toshiba 32A30 32" TV
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
90 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
