Question about Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU35
Still can't get video to display through the projector from the laptop. I have Vista Business as the OS, is there a different way to make it work because of Vista? I tried Marrie's suggestion, but couldn't see anywhere to see if the secondary screen was activated. I have selected the computer 1 and video or S-video (I have tried both) and the returned and still a blank screen. Am I leaving out something? Mike
  • Mike4398 Apr 26, 2008
    That helped some but I stil can't get video to display on desk top. I was able to get the "use this screen every time I present", and the mouse pointer moves on the screen, I was able to display slides from a PowerPoint presentation but it would not do the slide show and all slides would not display. It still may be a Vista problem. I was not able to locate any drivers from Sanyo site. It is the PCL-XU48, instead of the PCL-XU35.
    Thanks for the attempt. Mike
  • Sanyo Master
  • 13,433 Answers
First you need to make sure the device is connected.
Then you need to enable the vga / dvi out.
This can be done in your laptops bios.
also with a Function key combination (FN) in the keyboard then its one of the F1-12 keys.
Posted on Apr 25, 2008
  • Ekse Apr 25, 2008
    You might be able to activate it from your display settings.
  • Ekse Apr 27, 2008
    There are no drivers for these devices as they dont require any.
    Well have you tryed to drag the powerpoint window into the other screen / projector, as on my image the projector would be on the right so if you would drag the powerpoint window out from your laptop screen to the right it should appear in the projector.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Have you installed the drivers of the projector in the computer? If you have got the drivers it may be that vista doesn't support this projector!
Hi, I have a Sony projector at my office PLC XU35 Multimedia projector, from today color show yellow and not clear. what is the problem? please explain
It is a Sanyo model.
See page 33 of the
http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcxu30_im.pdf
you can adjust several things like Color, Tint, White balance, Sharpness, Gamma etc.
Also make sure to perform regular maintenance listed on pages 38 and 39
Sep 06, 2016 | Sanyo PLC XU35 Multimedia Projector
Have a Sanyo PLC-XU35. For some reason using it
Have you tried changing the refresh rate. It is located under "Control Panel, Display, Setting, Advanced, Monitor" I have had some success trying this.
Good Luck
Sep 24, 2009 | Sanyo Office Equipment & Supplies
The projector has a blue screen. The projector will not connect with the computer. We are using this for a presentation and can't get the projector to work with the computer.
Check all your connections to the computer then shut down the computer and restart. Try putting the setting on the remote to Computer setting. Also make sure the video setting are all correct in display on your menu.
Nov 20, 2008 | Sanyo PLC XU35 Multimedia Projector
Plc-xu35
are the other top controls working like power, menu,select etc??
remote problems can be caused by inproper code settings in the setting menu items.
try to switch to " code 1 "
Jul 12, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo pro xtrax projector
listen im a comp wiz on the remote press video 1 egt. if that doesn't work trash it
Sep 20, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
75 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
