Question about Kenmore 63942 Dryer
My Dryer will not turn on, checked door and plug in.
    Brigadier General:
  • 3,301 Answers
A kenmore is normally a whirlpool, if you have to clean the vent a lot you've more than likely blown the thermal fuse located in the back of the machine behind the back panel ,, remove and replace it
Posted on Aug 03, 2010
My tumble drier door isn't shutting so it won't turn on?
Make sure the wall plug is hot and if it is ok then check the dryer door safety switch, if that switch fails to connect when the dryer door is closed then the dryer will not start.
Jun 30, 2017 | Dryers
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
Even with the door open the dryer turns on
If you can turn the Dryer on even with the door open you have a bad door switch.The door switch is located on the dryer body so that when you close the dryer door it activates the switch.Be sure to turn off the power to the dryer and pull the electric plug before trying replace the switch.
Mar 13, 2011 | Dryers
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Dryer turns on briefly, then does not keep going. belt is fine and also manually turned to see if it was a reset. after turning on it dies...then after turning on nothing at all. power to motor is fine and...
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing
Jan 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Dryer will not turn on, but is plugged in. Light inside will not illuminate, either. What do I do?
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Jul 16, 2009 | Dryers
Dryer is getting Power but not coming on.
Check the following---
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 01, 2009 | Roper RES7646KQ Electric Dryer
Dryer won't start
hi,
1) Be sure your clothes dryer is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be aware that most electric dryers don't plug into standard 120-
volt receptacles; they operate on 240 volts.
Make sure the door is closed completely, the timer is advanced to the proper position, and the correct cycle is selected.
2) If the receptacle is dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the dryer and check the power cord and the terminal block. If necessary, replace the cord.
4) Open the door, and check the door switch. Press and release it; it should click each time. If it doesn't, it's probably broken.
If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service.
5) If the dryer still doesn't work, a thermal fuse or other electrical or electronic part may be faulty. The thermal fuse, found in the back cover panel, can stop working if the dryer overheats. Call an appliance service person if you suspect an electrical part may be malfunctioning.
Thanks for using FixYa
Jan 03, 2009 | GE Dryers
Won't work at all,
Hi Lanil,
The only things that will not allow the dryer to start are the following:
  1. I know you said you checked the breakers, but they could be the cause.
  2. The Child bouncing on the doorcould have broken the stub stub that pushes the door switch in.
  3. You may need to firmly press the Start switch.
  4. The dryer need to be plugged in, I know you checked it.
These are the four main things. Since the child bounced on the door, the trouble is most likely with the door switch. Try to use a stick or something to simulate the door closing and activate the switch and push the start button. If this starts the Dryer, and closing the door firmly does not, then the switches position or doors prod that pokes the switch, is not lined up or failiing to fully activate the door switch.
Nov 02, 2007 | Whirlpool LER5636P Electric Dryer
Dryer want turn on
Hi Airis0299,
Check the following:
  1. The door switch needs to be checked. Is the tab on the door inserting into the hole where the door switch is and making the switch activate?
  2. Is the Dryer plugged in good?
  3. Is the Circuit Breaker feeding the dryer tripped? This is on the electrical supply cabinet for your home. You will see a ganged(meaning two switches paired together) Circuit breaker. Turn the switch off all the way and back on to reset.
I hope this helps you get your dryer back running.
Oct 30, 2007 | Dryers
Kenmore 63942 Dryer Logo
65 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
