Question about Dryers
Dryer makes a lot of noise. I have figured out that the fan/impeller that is attached to the motor and forces air out of the exhaust vent is loose. I see where it says to turn it to tighten/loosen, but when I turn it nothing happens.
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerDryer makes a lot of - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gifElectric2_biDryer makes a lot of - 2_bing.gifass= Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 03, 2010
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
Tip
Troubleshooting Gas Dryer Problems
Drum Spins, But No Heat
  • Check the burner and the controls to see if they are faulty. Adjust the air shutter to readjust the air flow. Loosen the screw on the air shutter and move the shutter until the flame looks light blue in color.If this doesn't work, have the dryer serviced. Other problems could be the timer, thermostat or centrifugal switch, all of which can be replaced.
  • Motor On, But Drum Doesn't Turn
  • Replace the worn or broken drum belt that spins the drum. The idler and motor pulleys that spin the belt, the tension spring and the roller that the drum rides upon may also be causing the problem. Try tightening the motor pulley. Have the parts replaced, or the motor serviced.
  • Slow Drying Time
  • troubleshooting-gas-dryer-problems-3.1-120x120.jpg Clean out the exhaust vent, the exhaust paths and the lint screen.Check the door and drum seals to see if they are worn. If damaged, have the seals replaced. Replace the thermostat if it is faulty. Adjusting the air shutter may correct the problem.
  • Dryer Gets Too Hot
  • Unclog the exhaust vent and clean the lint screen. This holds in theheat instead of allowing it to pass out of the dryer. Make sure thatthe exhaust vent is installed properly. Try adjusting the air shutter.If the thermostat is faulty, have it replaced.
  • Dryer Makes Noise
  • Tighten any loose parts that shake as the dryer operates. Replace the worn belt, idler pulley or support rollers. The noise could also be a loose blower that will need to be fixed or replaced. Noise can also indicate that the motor bearings are damaged; if this is the case,service the motor.
  • Dryer Doesn't Operate
  • Check the power cord to determine if it is unplugged or damaged. If the door switch, thermostat, timer, motor switch or start switch is damaged, have it replaced. If the motor-overload protector was activated due to too many clothes in the dryer, let the machine restated cool down for 15 minutes.
  • on Dec 29, 2010 | Dryers
    Tip
    How to troubleshoot a dryer
    <ol> Drum Spins, But No Heat <li> Check the burner and the controls to see if they are faulty. Adjust the air shutter to readjust the air flow. Loosen the screw on the air shutter and move the shutter until the flame looks light blue in color. If this doesn't work, have the dryer serviced. Other problems could be the timer, thermostat or centrifugal switch, all of which can be replaced. </li> Motor On, But Drum Doesn't Turn <li> Replace the worn or broken drum belt that spins the drum. The idler and motor pulleys that spin the belt, the tension spring and the roller that the drum rides upon may also be causing the problem. Try tightening the motor pulley. Have the parts replaced, or the motor serviced. </li> Slow Drying Time <li> <span> <a><img src="troubleshooting-gas-dryer-problems-3.1-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.co.uk/images/a04/or/7r/troubleshooting-gas-dryer-problems-3.1-800X800.jpg'); }); </span> Clean out the exhaust vent, the exhaust paths and the lint screen. Check the door and drum seals to see if they are worn. If damaged, have the seals replaced. Replace the thermostat if it is faulty. Adjusting the air shutter may correct the problem. </li> Dryer Gets Too Hot <li> Unclog the exhaust vent and clean the lint screen. This holds in the heat instead of allowing it to pass out of the dryer. Make sure that the exhaust vent is installed properly. Try adjusting the air shutter. If the thermostat is faulty, have it replaced. </li> Dryer Makes Noise <li> Tighten any loose parts that shake as the dryer operates. Replace the worn belt, idler pulley or support rollers. The noise could also be a loose blower that will need to be fixed or replaced. Noise can also indicate that the motor bearings are damaged; if this is the case, service the motor. </li> Dryer Doesn't Operate <li> Check the power cord to determine if it is unplugged or damaged. If the door switch, thermostat, timer, motor switch or start switch is damaged, have it replaced. If the motor-overload protector was activated due to too many clothes in the dryer, let the machine rest and cool down for 15 minutes. </li></ol>
    on Dec 23, 2010 | Dryers
    My dryer wont dry laundry in1 cycle
    A lot of the times if a dryer starts taking numerous cycles to dry clothes it is because the vent to the outdoors has become clogged with lint. This keeps the dryer from being able to discharge the moist air. You can buy dryer vent brushes with a wire attached that you can use to keep the vent clean.
    Mar 04, 2014 | Dryers
    Trying to remove motor from a ctd00p dryer dont know where to start
    Has someone told you the motor is bad? (Please make sure the plug is disconnected and the exhaust hose is removed.) If so, the motor must be disconnected from the fan impeller and the housing for the element needs to be removed. Then remove the back panel and the motor will be visible. The threads on the impeller are reversed, try not to force it. The motors are expensive (I think that model is about $165.00) Hint: take the time to clean out the entire dryer, lint will be everywhere, also clean you exhaust hoses and outside vent. (Use a cell phone camera to take pictures as you go to help reassembly)
    Feb 02, 2011 | Dryers
    Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
    Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
    Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
    I have a Maytag dryer that started making a loud noise (loudest when first turned on) but was still functioning. We still used the dryer until we could get it repaired. Now the noise has stopped but the...
    Make sure to wash the lint screen with detergent and hot water to remove fabric softener deposits which block air flow. The noise may have been the air impeller (fan) which may have come loose from the motor. Have you checked for air flow from the exhaust? If nothing, look to the impeller. Hope this helps!
    Sep 23, 2010 | Dryers
    No air flow no blockage
    did you put the vent back together right, it might be as simple as a wire came off while doing the bearings, check all connetions on your wires first it is a seald system on the exhaust, so the fan that pulls the air out is the problem
    May 30, 2009 | GE DBXR463EDWW Electric Dryer
    Dryer vibrates with exhaust hose attached
    Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
    May 21, 2009 | GE Profile Harmony DPGT750EC Electric...
    A lot of moisture in the exhaust line of dryer...
    thats easy the moisture from your clothes ,,and the outside air,,where ever you live its a lot of moisture in the air,,now the cold air from outside is coming back in dryer and the hot moist air is trying to get out,,bingo condensation,,in your dryer exhaust vent tube ,,hince all the water,,,,now to fix that ,,we need to dump all the water from vent exhaust tube ,,you may need a new one because it will mostly rot...and check the flap or put a window exhaust kit on the house or window,,to stop air flow from coming back in the dryer ,,and where done..onthejob
    Jan 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
    Dryers Logo
    Top Dryers Experts
