Question about Canon PowerShot A710 IS Digital Camera
I put new batteries in They last for three shots then the battery light comes up and the camera shuts down. I have tried many different batteries its still the same.
  • Canon Master
  • 6,826 Answers
Http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a710_is
Issue: Batteries do not last very long in camera.
Solution: The PowerShot A710 IS requires repair service.
If all troubleshooting steps have failed, then the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below:
Request a Repair Online You can conveniently pre-arrange repair service with a Canon Factory Service Center through Canon's website. Find a Service Location Search to locate a repair service center and obtain further instructions. If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 pm. EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Friday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
Posted on Aug 03, 2010
I have a canon power shot A70 digital camera and I cannot get it to turn on even when inserting new batteries.
I don t have a solution, but I got a similar problem. When I install new batteries, they only last for maybe 10 snaps- snaps ,then the "battery" light comes on and camera shuts off. I ve tried several sets of different batteries so its not a battery problem.
Power shot A70-15 8.0 pixels 6X zoom
Maybe someone can help us out
Jerry
Mar 29, 2011 | Canon PowerShot A70 Digital Camera
Uses batteries very quickly and then shuts down until change to new batteries
Try this before you throw away the camera.
Digital cameras suffer if the battery terminals are dirty. Using a Q-tip and 99% pure alcohol, clean the battery terminals in the camera and on the batteries BEFORE you put them back in.
If you get good results, let me know.
Also, batteries specifically for digital cameras, like Duracell Ultra and Eveready e2 are WORTH the money.
Regular batteries 20 shots, special batts, 144 shots with flash and counting...
Mar 22, 2010 | SVP CDC-8680 Digital Camera
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Lens goes in and out three times when turning on or shutin off.
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is recommended.
Jun 15, 2009 | Sony Cameras
Camera keeps shutting down
Yes, that's sounds like a main board.
Mar 18, 2009 | HP Photosmart M417 Digital Camera
Camera not working - S85 Digital Samsung Camera
If you've had the rechargeable batteries for a long time, they can wear out. I would try getting some new rechargeable batteries or try some lithium batteries in your camera. They're a little more expensive but they're the best for digital devices and they last a little longer.
Jun 16, 2008 | Cameras
Change Battery Pack _ Ixus 70
Hmmmmm, the only thing I can think of, are you using the correct type batteries ? Check your instruction manual for the correct type of batteries, if you still have a problem I send it in for repair work or return it if it's new. Good Luck
Jun 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Power on n off
I had the same problem, corrected it by cleaning the battery contacts inside the camera.
Dec 21, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
A BATTERY PROBLEM WITH THE FUJI S500
Old motors and mechanism is eating too much power, thats what you will expect after three or more years using your unit. Digital cameras lasts for about three years working in good condition, after that expect your head to turn using that cam.
Oct 04, 2006 | Fuji FinePix S5000 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
262 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
