Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
ZT just quick, Husqvarna 48" deck with a 21hp kawasawki
Nothing with the key, New battery, Does crank at jumping at the soil-ode. Checked all safety switches- park, seat, blade engaged, control arms in out most position, and switched around 2 of the 3 relays... Checked all plugs including the dash plate... Any help would be greatly appreciated, Thank you, Gene
  • 2,100 Answers
It is the solenoid on the starter. Mine has been like that for over 10 years, I finally fixed it, had to get a hammer on it every time I started it. try tapping a bolt with a hammer, lightly, if it jumps up and starts, you know what it is. Check it out, might just be dirty. Hope this helps.
Posted on Aug 03, 2010
Why can,t I get power to starter on 24 h.p. hasqvarna
starter silinoid bad replace but first jump the starter to make sure its not bad
Sep 10, 2014 | Husqvarna 23 Hp 48" Deck Yard Tractor
Why can' I t get mower to do anything when trying to crank it over?
try jumping your battery with your car/battery. If that works, charge your battery and/or adjust your valves. If it doesnt, try jumping directly to the starter from the battery. If that works, get a new starter solenoid. If it doesnt, get a new starter.
Jun 09, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
My husqvarna tractor won't start. It has a new battery but no clicking or anything when I turn the key. If I hook up a portable battery charger and try to start it, I hear a grinding noise but the engine...
have you checked the fuse? there is a 20amp yellow fuse under the hood just below the solenoid same side as the blade engagement switch.also be sure all your lock out switches are working or by passed.
Feb 06, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower will not charge battery when blades are engaged.
safety switch wire maybe grounding out or insulation broken and touching body. how do u know they aren't charging. use a volt meter connected to the battery. crank engine, should be getting 13 volts plus on meter.
Jun 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna lawn tractor stalls when brake is
sounds like a safety switch most likely the one for your brakes
Jun 06, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Husqvarna 42'' deck 20 hp kohler won't start
sounds as if you have one of the safety switches keeping the starter from cycling. If it cranks over when you jumper across the starter solenoid then it is a safety switch. they are usually under the seat, on the clutch pedal, on the blade engagement lever and on the gear shift which has to be in neutral
Aug 14, 2009 | Husqvarna Garden
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
90 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
