Question about Nokia E63 Cell Phone
Dont know how to insert sim card in E-63 phone
5 Suggested Answers
  • 43 Answers
SOURCE: MY NOKIA 6300 IS SAYING 'NO SIM CARD INSERTED', BUT THE SIM CARD IS INSERTED. WHAT CAN I DO?
no problem.. jus remove your sim card and reinsert it. .sometime it may happen like this..
Posted on Sep 06, 2008
manojro
  • 495 Answers
SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Posted on Nov 26, 2008
  • 14 Answers
SOURCE: instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
Posted on May 05, 2009
  • 699 Answers
SOURCE: keep saying insert SIM card
You are trying to use a SIM from another Network or Handset but your phone is LOCKED to your old network and/or to a specific SIM card and number: this is why it is asking you for the unlock code to remove the restriction. It you are no longer under contract or obligations (such as minimum total recharge amounts for apre-paid handsets), then you could try to request the unlock code from the original service provider of your handset.
As for asking to insert SIM card, make sure that the SIM is correctly and securely inserted in your handset SIM holder. Also check that the SIM is still functional by inserting it in another handset: SIM card can be permanently and physically disabled if you attempt to enter too many consecutive invalid codes (usually around 10).
Hope it helps and good luck!
Posted on Jan 25, 2010
E 63 insert sim card
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Nov 12, 2012 | Nokia E63 Cell Phone
Im trying to get pictures from motorola razor phone but is asking me to insert a sim card and i dont have one at all i lost it ... and i want to know is there any way i cant get pictures from this phone...
You can use P2K phone commander, it can dump all the phone data even with no sim card inserted.
Here you can get the program and the drivers http://www.themotoguide.com/downloadsoftware.php
Do not delete anything! Since this software is not official and you can access some system files with it, deleting stuff at random will lead to unpredictable results
Mar 19, 2011 | Motorola Mobility RAZR V3
How to insert sim in nokia e 63
moz-screenshot.pngHi,
i have attached image for your reference.Follow the instructions given there to insert SIM card.
Regards,
Nandy
Nov 11, 2010 | Nokia E63 Cell Phone
SIM card is not showing up. Phone only says insert SIM
is the phone unlocked (no carrier's name on it) just motorola...take the sim card and cell to the carrier that you are on...(exchange the sim card) this is free of charge...tell the rep..you woke up this morning and tried to turn on your cell..and it reads insert sim you dont know what happen...
Jun 04, 2010 | Motorola Cell Phones
I dont know where to insert sim card in lg vu cu920?
Slide the back cover off, remove battery, look for 3 gold dots right above the micro sd text written on the silver colored metal
May 21, 2010 | LG Vu CU920 Cellular Phone
Keep saying insert SIM card
Jan 25, 2010 | Nokia 7260 Cellular Phone
Keeps saying 'please insert sim'
Your SIM card is not being read anymore due to a number of reasons.
Try rubbing the SIM card with a clean smooth dry cloth and then insert it again.
If that doesnt work, your SIM might be damaged, take it to your network provider and they will replace it, hopefully with your same phone number.
Nov 15, 2009 | Samsung SGH-J750 Cell Phone
Insert simcard nokia 7200
hi the only one thing you can try without replacing the sim card reader is do you know when you put the simcard in if you push on the simcard with your finger so your pushing it down onto the contacts is fold up some paper so that it put pressure onto the simcard when you put the battery on as alot of times the contacts dont touch the sim card properly so putting some folded paper on top of sim card pushes it down onto the contacts properly.
This solves the problem in most cases but it can be difficult to get right as if the paper isnt thick enough then it might not push it down hard enough to make contact.
If after doing this it still dont work then this either means the sim cards no good but you could try it in another phone or it could be that the sim card reader is not connecting with the board properly and would need replacing.
Make sure you check the contacts are clean on the sim card and the sim card reader to make sure this isnt problem.
If you have not tried the sim card in a different phone then it could be the sim card is no good.
Did this sim work in the phone before just in case the phone dont accept that network as you can get this message if this is the case.
Let me know how you get on and if you need further assistance ok
Apr 08, 2008 | Nokia N95 Cellular Phone
Nokia E63 Cell Phone Logo
182 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
