Question about Kenmore Dishwashers
Kenmore dishwasher motor hot, sprays little water
  • ivanmondaca Aug 03, 2010
    It sounds like the motor is trying to run but it makes some noises, sprays very little water and stops.
    After that there was a burning smell and inside the machine there was smoke or maybe vapor.
  • 901 Answers
Check the motor especially the pump side parts. Some debris might be stuck. It is not allowing the motor to rotate freely.
Do not use the machine as finally it may spoil the motor coils.
Posted on Aug 03, 2010
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Kenmore dishwasher we use new finish detergent and the little soap pouches do not dissolve.
DOES THE SOAP DISPENSER DOOR OPEN, IF SO THEN EITHER THE WATER FROM SPRAY ARMS NOT REACHING THE DISPENSER, POUCHES IMPERVIOUS TO WATER OR REQUIRE HOT WATER AND WATER IS NOT HOT ENOUGH. CHECK THAT THE SPRAY ARMS ARE NOT CLOGGED WITH DEBRIS. ALSO COULD BE SOME UTENSIL KEEPING THE SPRAY ARMS FROM ROTATING.
Mar 09, 2010 | Kenmore Dishwashers
My kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Jan 14, 2010 | Kenmore Dishwashers
My dishwasher is not cleaning dishes - it is running through its cycles, but when it is done, there is a heavy residue of soap and hard water and the dishes looks worse than when i put them in.I've changed...
Hello there:
There are 6 areas that could cause this to happen Please follow these simple steps ok
Investigate each of these six areas if your dishwasher is not completely cleaning your dishes:
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Cycle Selector Switch
Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
Dec 30, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore model 6651701 arms are not moving, water has no pressure to move arms what is the problem, is there a motor, filter?
water is sprayed up a cylinder to the arms which usually spin you may be able to lift the arm off and check the oulet holes for clogs if this is the problem clean them out and purcase a bottle of dishwasher cleaner use it on wash cycle at least once a month.just place the bottle upside down in the metal utensil tray in the bottom of the dishwasher make sure there is nothing else in the machine and make sure that the water is hot by turning on the hot water tap before you start the cycle,,,Cleaner also has instructions on the label avaiable atanystore that sells your diswwasher soap
Dec 16, 2009 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Top spray arm in dishwasher will not spray
poor water pressure due to a clogged flowplate assy if the flowplate assy is not clogged with gook and hard water then you may need a new motor, a weak motor may not push the water well enough to get up to the top
first check entire flow are impeller etc
Oct 08, 2009 | Kenmore Dishwashers
Kenmore 665.1736 fills with water but does not spray
Take thre drain hose off from disposal. Pour hot water down the hose until full. Cover end with hand. Press cancel/drain while holding hand over hose - over bucket. That may unstick checkvalve balls and or fix air lock. I have to do that every 6 months or so. Started happening 1 month out of warranty. Go figure. Not a fix - just a work-around...
Dec 28, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
