Question about Clarion VS755 DVD Player
Is there a replacement for the VS755 that has a DVD player that fits exactly into the VS755 mounting metal sleeve. Thanks
JVC KD-S595 car stereo. Trouble removing
It depends what kind of car it's installed into and the mounting technique used. Removal keys apply only to a radio that has been DIN mounted (ie: metal sleeve utilized). Many vehicles or radio kits use the ISO mounting method which involves screwing into the sides of the radio to secure it. Keys will not help in this situation. The dash or radio trim must be removed to access the screws on the sides.
With the front trim of the JVC removed, you should be able to see the metal sleeve around the radio if it was used. If not, the radio was ISO mounted.
Dec 26, 2013 | Car Audio & Video
VW Sharan return power steering hose leak at connection to pump
The hose needs replacement or you could try bringing it to a hydraulic fitting shop and have it repaired.
Apr 27, 2017 | Volkswagen Passat Cars & Trucks
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
The metal sleeve that fits over the frothing arm on our Breville Espresso machine, went down the disposal and got damaged. I can't find a replacement for it!
Here you go: http://www.ereplacementparts.com/breville-800esxl-diecast-espresso-machine-parts-c-116052_116055_116066.html
It's part number 156. Check it out on the diagrams they provide to verify. I have the same machine and am missing the exact same part, so I know exactly what you are talking about!
Nov 02, 2010 | Microwave Ovens
Have just purchased a cde-100 for an mx3. Does the "mounting sleeve" come with the unit? If so, is it attached to the unit as shipped? I am studying the installation instructions. Are there more explicit...
mounting sleeve is on the radio when you buy it in most of my experiences.
reinforcing the HEAD UNIT-(the cd player itself) with metal straps means that the DIN(the hole the radio goes into in your dash, either single or double) dash piece is probably made of a softer material, and you should mount a small metal strap, usually does not come with the unit, to the units mounting sleeve, and then mount it to the inside of the dashboard of the car with some screws or bolts. this will keep the cd player from moving around, bouncing, etc while you drive over bumps and such.
you could probably get some metal mounting straps either from the box the radio comes in (very few come with them) or get a dash install kit from an auto parts store or a walmart for your car that will probably include all of the things you need including the dash piece, any mounting hardware, and metal straps the factory recommends or deems necessary, and even a wiring harness adapter.
Aug 19, 2010 | Alpine Car Audio & Video
LOOKING FOR THE METAL FRAME THAT THE RADIO SLIDES THROUGH
it is called a sleeve try car toys or quality auto sound
Feb 23, 2010 | Jensen CD-2010X CD Player
Sleeve seems to be too big, how do i securely fit the radio in?
Hello 3134,
I'm assuming that you have the correct mounting sleeve. If not, you need the one that was delivered with the radio or an exact replacement. Also, once the receiver is inserted and locked into the sleeve, you need the appropriate "keys" to release it from the front.
There are some little metal "fingers" (tabs) that need to be gently bent inward until they securely contact the recesses built into the receiver case. The best technique is to push the tabs slightly from the outside and with one hand inside the sleeve, pull on them from the very tip. To insure that the case is centered, bend all of the tabs about an equal amount.
Hope this helps.
Sep 27, 2009 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
HEADREST dvd player honda odyssey 04 exl
Do the headrests detach?? If they do, you can buy the pair of 7" headrest DVD/Monitors all-in-one from Farenheight (made by Jensen). I have used these several times. Not only do the headrests match,but the product lasts too! The best part is that they are about 1/2 the price of many others.
Larry T
Winona Lake, IN
Jan 28, 2009 | TMI Products Vizualogic Headrest Pair...
Parking Brake Wire
I have not a solution but a remedy. If you would like to be able to watch movies while driving, follow these simple instructions. Take out the dvd player, Get one simple toggle switch, install somewhere easily accesible. Now run the parking brake wire from the dvd player to one of the prongs on the switch. Now find a good solid metal ground under the dash, (mounting brace,etc.). Run a wire from this ground to the other prong on the switch. Now reinstall the dvd player, turn on, when blue screen appears, flick the switch, hold for 5 seconds, then flick it back, in a few seconds it should go to the normal screen.
Feb 19, 2008 | Jensen VM9410 Car DVD Player
Clarion VS755 DVD Player Logo
82 people viewed this question
Top Clarion Televison & Video Experts
ray gallant
Are you a Clarion Televison and Video Expert? Answer questions, earn points and help others
