Question about Samsung HLN617W 61" Rear Projection HDTV
We have a Samsung HLN617W rear projection TV with a collapsed light tunnel. Is it possible to get a replacement part?
    Sniper:
  • 63 Answers
Shopjimmy partstore just to name a couple. Ebay also carries refurbed parts. Or type in the part number for your model/unit and run a net search..
Hope that helps
Posted on Aug 03, 2010
SAMSUNG HLN617W which comes on for 20 minutes then gets three blinking lights
You have found the fault! Clear the exhaust filter as there is not enough air cooling the lamp housing.
Mar 04, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Tip
Rear projection TV displays a shadow on one corner or side of the screen.
Hi.
This tip may be helpful only if your rear projection TV is displaying a darker shadow on one portion of the screen. If the shadow shape and size will not vary, that means that there is probably a detached mirror in the device called Light Tunnel, located inside your TV.
Most rear projection TV works projecting the light from the internal lamp on the screen. Before reaching the screen , the light will pass through a 'pipe' whose internal surface is covered in rectangular mirrors, located all over the tunnel surface.
A quite common fault is caused by one of the mirror detaching from the the light tunnel internal surface , and falling down or hanging in there. This will be seen on the display as a darker shade located near to one side of the screen.
The light tunnel is located in the light engine. To repair the problem the TV must be disassembled by a technician. Accessing and disassembling the light engine is not a repair that can be done by the owner.
Click here to view pictures of a light engine for a Samsung rear projection model. The tunnel is the optical device located in the light engine.
If you are a technician, to replace the light tunnel you will have to take apart the light engine, that apart of being quite a sensitive optical device, is also the most expensive part on a rear projection TV.
In that case you may find useful the service bulletin posted below, that is illustrating how to replace the light tunnel on a light engine for Samsung rear projection TV. Please be aware, that if you attempt doing this operation without sufficient knowledge and experience, you may damage your TV set beyond repair, as the light engine is very expensive.
How to replace light tunnel on a Samsung rear projection:SERVICE BULLETIN
The file is on PDF format.
Regards.
Ginko.
on Feb 05, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
(4) Light Tunnel Mirrors Came Apart
i will email you piks u need to use high temp sealer
May 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W wont come on
Unit does not have a flywheel. Assemblies include lamp, ballast, color wheel, dmd board, light tunnel, main and/or digital and analog pcb as well as power supply. These are all the assemblies in DLPs. The problem you described is usually lamp or ballast, but can also be from dmd or other circuit boards. Make sure lamp cover door safety switch is secure and fully engaged after replacing lamp or removing rear cover. I admit these sets are not cheap to repair. Good luck, Russmann.
Mar 27, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Diagonal Shadow
Often a piece of foam, debris or such can get in between the lamp and color wheel which can cause the symptom your describeing.
Mar 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
