Question about Maytag Dryers
My maytag neptune dryer will not stay running and sometimes will not start at all. We cleaned all the vents out . It is a Maytag Neptune MD55
    Scholar:
  • 32 Answers
Try this (you may need two people):
1. Open the dryer door and locate the door switch. While pushing the door switch in, have someone else push the start button.
2. You'll hear the noise. Keep pushing both buttons and take your other hand, reach in side and grab one of the drum fins and manually push the drum in a clockwise direction.
3. The drum may take off on its own. BE CAREFUL TO REMOVE TO HAND QUICKLY TO NOT GET BUMPED BY THE FINS AS THEY BEGING TO ROTATE.
If it does not start, the motor needs to be replaced. If it is still under full warranty, simply call a repairman.
If this works, turn the dryer off, close the door and try to start it again just by pushing the start button. If it works, it may have been something obstructing the drum from turning. OR, the motor could be going out. It may continue to start on its own for an unkown period of time, a day, a week, and year. But eventually it will go out and will need replaced.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are Amana certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide.
Best, G
Posted on Aug 03, 2010
I would like to find out if my Maytag Neptune dryer has heat coils or just a Flame sensor
Go to YouTube and type in - Maytag Dryer heat coils and see if it comes up. Also type in Maytag Neptune Flame sensor on the next search.
Oct 05, 2015 | Maytag Dryers
Why is my Maytag Neptune Elec Dryer MD55 chirping? How can I fix it?
Could be a bad spot on the drive belt. Each time it moves over the motor pulley it slips. If the chirp is happening at the same interval over and over I would check the belt.
Mar 28, 2015 | Maytag Dryers
I maytag neptune stacked washer and dryer model # mle2000ayw just recently the dryer started to act up it doesnt wanna dry the cloths all the way so we have to put it over again !! sometimes 3x ...
hi gar.... sounds like your dryer vent pipe or outdoor vent is partially clogged with debris. thoroughly clean it out and it will work great once again. Joe
Jun 17, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
Have a maytag neptune dryer md55 cannot get a small enough tool to adjust legs to help balance. any suggestions
use some ceader shake shingles ther tapered and the bugs hate it and it smells good this will shim the unit and break off what you don't need. hope this helps
Aug 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer sometimes dries sometimes not?
Hi, Have you checked the venting that goes outside. Most of the time, this helps especialy because it is electric dryer.
If I can help further, please let me know. Thanks
Vic
May 11, 2009 | Maytag Neptune MDG9700A Gas Dryer
My neptune dryer
the wire my be off the sensor , but when you say it worked after cleaning vent makes me think the vent needs more cleaning, the dryer is designed to run until the clothes are dry if that takes 4 days it will run 4 days, if the vent is not good it cant dry, remove the vent and run a load see what happens with out any vent on it
Apr 30, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
151 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
