Question about Dryers
My clothes dryer needs a drive belt. Length is 2230, width 6mm and with 3 grooves on one face. The unit has a tensioner so some latitude is possible. Can you advise please. William Hartley hartleyfm@yahoo.co.nz
    Sergeant:
    Champion:
  • 277 Answers
Hartley,
Goto partselect dot com and put your make and model# and you can get a belt at a good price
The model# should be upper left coner whem you open the dryer door
Posted on Aug 03, 2010
We have a 2001 chyrsler voyager we are trying to put a belt that turns the alternater and power steering pump and we don't know how to do it
Instructions Things You'll Need:
  • Wrench
    • 1 Study the exact path the drive belt follows across the pulleys and make sure you know it or write it down in a diagram.
    • 2 Loosen the drive belt tensioner by loosening its upper locking nut with a wrench, then slip the drive belt off the crankshaft pulley first and remove it from the others.
    • 3 Take the old drive belt with you to the auto parts store so you can use it to help get the correct length, width and design for the replacement belt.
    • 4 Install the replacement drive belt onto the pulleys, making sure it runs in the same path as the old one. Check and make sure the belt fits properly in each of the ribbed grooves within the pulleys.
    • 5 Adjust the drive belt tensioner until it gives the belt the proper tension and tighten the locking nut. On some engine types. the belt uses a dynamic tensioner that will automatically set and maintain the correct tension.
hope this can help you.
Dec 24, 2010 | Chrysler Voyager Cars & Trucks
Timing belt replacement
hello,
The solution provided below will be of great assistance to you;
1.Ensure to Study the exact path that the drive belt follows across the pulleys and make sure you know it
2.Loosen the drive belt tensioner by loosening its upper locking nut with a wrench, then slip the drive belt off the crankshaft pulley first and remove it from the others.
3.Take the old drive belt with you to the auto parts shop so it can help you to get the correct length, width and design for the replacement belt.
4.Install the replacement drive belt onto the pulleys, making sure it runs in the same path as the old one. Check and make sure the belt fits properly in each of the ribbed grooves within the pulleys.
5.Adjust the drive belt tensioner until it gives the belt the proper tension and tighten the locking nut. On some engine types. the belt uses a dynamic tensioner that will automatically set and maintain the correct tension.
Thank you...
Sep 06, 2010 | 2001 Dodge Caravan
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
How do you tension the dryer bet on a Kenmore 80 series dryer
you will have to loop the belt through the roller first then while you are installing the belt around the drum it will have tension. two people will need to install this since you have not done this before I assume. One to hold the drum up for you
Feb 24, 2010 | Dryers
Td4112 which way does belt fit around drive and
check the drive it should have grooves on it. that means that the belt grooves should go around the drive and facing the drum. When you see the belt on the drum you should not see the grooves on the belt
Dec 31, 2009 | Zanussi TD4112W Electric Dryer
My air conditioner compressor is frozen, the alternator belt is running off of the AC pulley. Does any one make a pulley system to replace the compressor unit so I do not have to replace compressor. Car is...
An easier solution and much cheaper would be to buy a shorter belt.
To find out what size belt you need simply run the route with a piece of string excluding going round the AC pulley. Measure the length in MM, then count the groove in the original belt.
Lets say the length of the string works out at say 1202mm and you have 6 grooves in the original belt, that will make the belt part number 6FPK1202
Call the local parts centre and ask for the nearest they have to that number.
The width (6 groove) must remain the same but the length (1202) can alter slightly as you can take up slack on the belt tensioner.
Hope that is worth 4 thumbs up!!
Nov 21, 2009 | 1996 Nissan Maxima
Whirlpool model WGD5300SQ dryer belt is off, roller is laying loose, is there a diagram?
If the belt slipped off, this will cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To re-install, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jul 18, 2009 | Dryers
The Belt Tensioner came off of my Whirlpool WED5300SQ0 Dryer
Jul 14, 2009 | Dryers
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 | Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
Marvin
Marvin
