Question about Adobe Acrobat Professional 7.0 for PC
Page numbers in PDF
I've read all the help on showing page numbers and changing page numbers in a PDF but nothing seems to work.
I've inserted the page numbering footer but I need to change the page numbering. I changed the page numbering from the toolbar but it's not changing the numbering view on the actual page. What am I doing wrong?
  • 45 Answers
Change the number in the pages tab. right click any page and select number pages
Posted on May 04, 2008
How can I get my kindle paperwhite to show what page of the booh I am on
How to go back to first page on Kindle Paperwhite?
Go to a specific spot on your Kindle Paperwhite. You can also jump directly to various parts of a book. Tap near the top of the screen to display the toolbars, and then tap Go To. A pop-up window appears.
How to Move through a Book on Your Kindle Paperwhite - dummies
www.dummies.com/.../kindle/how-to-move-through-a-book-on-your-kindle-paperwhite... Search for: How to go back to first page on Kindle Paperwhite? Feedback
About this result
Amazon.ca Help: Reading Basics
https://www.amazon.ca/gp/help/customer/display.html?nodeId=201733740 To use Time to Read: While reading, tap the top of the screen to show the reading toolbar. Tap the Display Settings (Aa) icon, and then tap the Reading Progress tab. Select your preferred tracking option to be displayed at the bottom of your screen: Location in book. Page in book (if available) Time left in chapter.
Amazon.com: Customer Discussions: Kindle paperwhite updated, no ...
https://www.amazon.com/forum/kindle?_encoding=UTF8&cdForum... May 27, 2014 - Hi, Seems my Paperwhite just got an automatic update. ... You'll only see the "Time left in chapter" if the book has been divided into chapters by the publisher. ... In reply to an earlier post on Dec 6, 2014, 9:29:04 AM PST. page number instead of location ...
7 Apr 2016
Page numbers not showing - 2nd ...
1 Oct 2015
No page numbers, new paperwhite ...
16 Nov 2013
Paperwhite page numbers?
3 Oct 2012
More results from www.amazon.com
How can get my kindle paperwhite to show what page of the book am on...
Jun 21, 2017 | Tablets & eReaders
PAGE NUMBERS NOT SHOWING
What is the procedure you are following to insert page number?
Here is guideline to insert page numbers.
http://support.microsoft.com/KB/179079
Jul 02, 2014 | Microsoft Publisher 2010
I can't figure out how to reverse the door on my
You need a left sided hinge kit...here is the link to the part from Bosch http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodlg.htm?Maktx=wtz1260&eshoptype=A
There is a PDF on their site under "support" and your model number wtmc3321us that shows this on page 8. Hope this helps you! :)
Jun 11, 2012 | Dryers
Print preview does not show full page
Go into the Page Setup for the email program that you are trying to print from and this should allow you to change the print settings.
For example, in Mozilla Thunderbird, if I go into File then Page Setup, on the Format & Options tab I get an option to Shrink to fit page width, plus can change the page orientation (Portrait or Landscape).
On the Margins & Header / Footer tab I get further options I can use to control how big the page margins are and what header and footer information gets printed, i.e. page title, page numbers etc.
Once you've changed the Page Setup values, see what has changed for you on the Print Preview
Dec 23, 2011 | Dell Inspiron 15R Notebook
How do I scan a multi-page document into one pdf file? Every time I try, the machine creates a separate pdf for each page.
From the University of Texas. This document shows how to combine PDF files using Word or Word Perfect.
Combining Multiple PDF Files Into One These instructions assume you chose to label the first of your multiple PDF files "etd.pdf" as suggested in "Creating PDF Files in Word or Wordperfect for Windows".
  1. Open your "etd.pdf" file in Adobe Acrobat.
  2. Select Insert Pages from within the Document menu.
    [view step 2 illustration]
  3. A Select File To Insert popup box will appear. Highlight the file you wish to append to etd.pdf and then select the Select button. (this process will be easiest if you work your way from front to back through the dissertation, appending successive sections to the first file, "etd.pdf")
    [view step 3 illustration]
  4. An Insert popup box will appear. If you are following the suggestion under Step 3, select the After option under Location. Under Page determine exactly where you wish the selected file to be inserted. If you are assembling the dissertation section by section, you will want the file to be inserted after the last page of the current section. In this case, select Last. Select OK to complete this step.
    [view step 4 illustration]
  5. Check the updated "etd.pdf" file within Exchange to make sure this is proceeding in the order you want.
  6. Continue to add subsequent files in the same way.
  7. When you are finished, exit Exchange and save the file under its original name, "etd.pdf".
Hope this helps. I saw nothing in the printer's manual about doing this.
Also Adobe Acrobat will do it also.
Good Luck
Feb 18, 2010 | HP LaserJet 3330 All-In-One Printer
Hi! I am having a problem editing page numbers in adobe
Rotate the page before inserting a box for the page number. You have to use the Forms function to insert a box and add the page number. Then Rotate back. Then print the form to PDF. When you open page number will be where you placed it.
Nov 24, 2009 | Adobe Acrobat Professional 7.0 for PC
My document has a cover and a table of contents. I want page numbering with one to start on the third page. I did do the page break for the cover and the contents and was able to start the document on page...
There are two ways to do this. The first way SOMETIMES works. If you don't have luck, try the second method.
Method 1:
  • Delete the page break between the end of page 2 and page 3
  • Position your cursor at the start of page 3.
  • Click on Insert / Break / Next page
  • Select all the text form page 3 to the end of the document.
  • Click on Insert / Page numbers. UNCHECK "show number on first page"
  • Click on <Format>. Make sure "Start at" is selected and the value is "1". Select <OK>
  • Select <OK>
Method 2:
You need to work with the headers and footers. When you are done, you'll have two different footer sections that are NOT connected.
  • Add a "next page" section break as you did above.
  • Click on View / Header and Footer
  • On the Header and Footer toolbar, Click on the icon for "switch between header and footer"
  • page down to page 3. Click on the "link to previous" icon on the header and footer toolbar
For some reason I occasionally have to do this twice to get it to stick but eventually it should work. The key is to make sure you have two separate footer sections; the first section is page 1 and 2 without page numbers then the second section (starting with physical page 3) that has page numbers starting with page 1
Sep 10, 2009 | Microsoft Word 2003 for Students &...
Microsoft Pub. moving/deleting pages deletes others?
If you want to delete a whole page from publisher, then look at the bottom left hand side of the screen where your pages will be thumbnails that are numbered. Rightclick on the page number that you want to delete and click on delete page.
Oct 02, 2008 | Microsoft Office Professional 2007 Full...
Adobe Acrobat Pro 7.0 Can't get page numbers to show
OK, That's why it's not working.. In order to get them on there, do the following:
Once you have loaded the page into acrobat, goto the Document Menu, mouse over header and foot, and choose add..
In there, there will be a button that will say "insert page number", just click on that (only once), then click "ok".. That will add page 1...2...3...4, etc to the top of every page.
As a side note: you can also choose where to put the page number by clicking in one of the text boxes marked "Left Header", "Center Header", etc.. and then click on "insert page number".. You will be able to see a preview first before actually adding the numbers..
Mar 29, 2008 | Adobe Acrobat Professional 7.0 for PC
Adobe Acrobat Professional 7.0 for PC Logo
400 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
