Hi I have a Simpson 7.5kg top loader machine model no 22s701E. The water keeps continually filling. I have to turn the taps off for it to stop otherwise it overflows everywhere.
  • 343 Answers
Water inlet valves operate when power is supplied to them. If you turn the machine off or pull the plug and the water stops it means that the inlet valve is ok. If the water continues to run with no power to the valve then the valve is faulty..
Replacing a crook inlet valve is not a big job for a tech..
Good luck....Nomess
Posted on Aug 03, 2010
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Simpson Enduro 801
turn the timer to a setting and pull out on the knob once
Apr 09, 2015 | Simpson Washing Machines
Simpson washing machine
More info would be helpful (model? top loader/ front loader?)
If it fills then stops filling (ie. knows that it is full) yet does not turn, and no sounds etc, it is likely a motor control module or motor start capacitor or maybe PCB (If fully electronic). Does it spin if you manually turn the cycle to the spin point?
May 27, 2014 | Washing Machines
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
My fisher paykel top loader won't do a cold wash.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
May 20, 2011 | Fisher and Paykel Washing Machines
Hi, Weve got a simpson esprit 700 washing machine and the cold water tap seems to be blocked. I've disconnected the hose at the washing machine end but when I've turned it on in the sink it works fine so...
Hi just read your posting.There are 2 types of SIMPSON ESPRIT washing machines,There is a top and front loader version.Which one is yours?Please reply and I will guide you on replacing the water valve.Looking forward to your reply.
Sep 19, 2010 | Washing Machines
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
My simpson top loader will not complete cycle.
More likely than not it is your control regulator gone out. This is where your rotary knob is.
Dec 07, 2009 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
