Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have rca rear projection hdtv and convergence is messed up looks like 3d image. Convergence option has disappeared. Help!!
  • RCA Master
  • 8,617 Answers
Very easy repair. You need the RCA repair kit called the ITC222 and ITC222A convergence option missing repai kit available from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Posted on Aug 03, 2010
Picture appears concave and doubled
Most likely scenario is that the auto convergence option has disappeared which will cause the set to have an arced picture with double images. You can get the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with instructions.
Jul 31, 2010 | RCA HD52W56 52" Rear Projection HDTV
My auto convergence has disappeared, and my colors are messed up
The ITC222 and ITC222A convergence option missing repair kit fixes tha issue. The kit is available at www.tvrepairworld.com and has complete instructions on CD
Oct 07, 2009 | RCA HD52W59 HDTV Projection Television
I have 3d on my 52 inch rca and go to set up convergence isnt there now.is this something i can fix?
Yes its a easy an inexspensive repair. www.tvrepairworld.com has the ITC222 and ITC222A convergence option missing repair kit. The kit contains the parts and CD with instructions.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen looks 3d and schrunk
this is an indication of convergence failure. on these model the first suggestion or more like question is this do you have the convergence option in the customer setup menu? If you dont i suggest you read the fl231 problem in the tips and tricks section of this website. If you do and you still have the bow tie three d effect then the next solution is to replace what is known as convergence power supply. note when you start replaceing the boards that effect convergence it may need adjusting that a technician needs to do
May 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rca look like 3d picture
You have a convergence problem. The Red and Blue are out of convergence meaning they are out of synch, causing shadows. There should be an Auto convergence option either on the television or through the menu options on the remote. If this doesn't fix your problem, then there's a manual convergence option. Should that fail, a service call is in order. Best of luck!
Greg
May 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
Apr 04, 2009 | RCA Televison & Video
3d image
This is what known as a convergence problem. First question is in your setup menu do you have a convergence option.. if you do then do you have any control in that mode does the crosshars move up and down and side to side... if you dont then you have a convergence power supply issue.. if you do it could be a setup issue. IF you do not have convergence in your setup menu then it possiblely be a special fuse.. and bad electrical connections. so let me know and ill see if we can narrow it down further
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Warped 3D vision on the screen
convergence is out? convergence is not available in setup menu? this points to eather convergence power supply out or you might wont to look at fl231 fuse.
Mar 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
