Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold So can you purchase the board somewhere and install it yourself? Whirlpool recommended a guy that's quoting me over $300 to fix this! that's ludicrous! your thoughts?
    President:
  • Whirlpool Master
  • 2,651 Answers
Sure look up the model nuymber on sears.com ( under parts link). adn look for the circiut board by picture. 2 screws and a few wires, no p[roblme doin your self
Posted on Apr 27, 2008
Where can i find a wiring diagram for whirlpool control board w10135090?
Normally unit technical sheet is hidden for technician reference inside the front bottom kick plate or just under it. Please put it back after using it to the right place. Next guy working on your fridge need to refer that.
Sep 03, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
It's a Sony 32 inch flat screen led tv. Has line going across screen about 4 inches from top and faded verticals lines across tv. Anyway to fix that
one of the circuit board needs repairing replacing. I wouldn't recommend trying it yourself even though it wont be too difficult but without electronics knowledge you could end up getting the wrong parts and wasting good money. Parts aren't cheap so get a quote from a repair guy and prepare to replace the TV if it's dear
Jan 11, 2013 | Televison & Video
Whirlpool Gold dishwasher Model GU1200XTLB3 Problem: Heat stays on when washing ends. The only way it will go off is if the door is left open. This happens with every use. I have tried the...
Hello, Thank You for using FixYa. I will be helping you today.The relay on the control board is fused closed. Control needs to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Sony WEGA kv-32" TV
The "D" board is the main circuit board assembly containing most of the set's power and deflection circuitry. It's the board that typically causes most of the problems because there's so much on it. Unfortunately, this board is no longer available from Sony as a part, and must be repaired to the component level. Many shops don't want to (or can't) get into that depth of repair, so they quote a high price on board replacement. There is no single part you could order to repair this board yourself, I'm afraid. There are some companies in the business of repairing boards, but you're still looking at $200 to $300. With the price of a 32-inch LCD set now around $300 to $400, there's no point in trying to fix a TV when it's just a few dollars more for replacement.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
5 year old Whirlpool Gold washing machine wont spin or drain. I hear the motor hum, but wont engage. Number is GST9630PW1
Easy solution: NEVER BUY A WHIRLPOOL PRODUCT. It's only 5 years old. You spent good money. In reality, this machine is doing exactly what WHIRLPOOL Corp. programmed it to do: FAIL.
NOW, you call the service guy. They tell you it will cost about $500 to $600...which is really not a good solution. Because in 5 years, this stuff happens. The best solution is to BUY A NEW WASHER. Mission accomplished! Sell product. FIX -ha! That's how things were when our grandparents purchased appliances. Parts could be replaced. That's no longer the deal.
Dec 09, 2010 | Whirlpool Washing Machines
The start button on my master chef microwave won't work
You need a new control board. You can either bring the model number of the microwave to a parts store and buy a replacement and install it yourself, or you can have an appliance repair guy come look at it. I recommend the appliance repair guy if you arent handy because there are a lot of wires going to the control board and youll have to remove the outer casing of the microwave to get at the board.
Dec 13, 2009 | Washing Machines
I have a similar problem...my control panel is dead.
It's definitely the control board. I would recommend that you buy it at repairclinic.com and then call a technician to install it. You'll save a lot of money that way.
Good luck.
Sep 08, 2009 | Whirlpool GEW9250P Electric Dryer
I have a Whirlpool Gold, had 4years,had to replace
Thermal fuse mounted to the control board see if you have power on each side of it checking from post to ground,if you got power going in but none going out it's blown,and has a more serious issue somewhere.
Aug 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool side/side ice dispencer not working
I had the same problem, however, the ONLY fix was to call the repair guy and get a new part. I took it out, defrosted the unit thinking ice was in the gear mechanism, lubricated and re-installed it to no avail. The repair guy had SEVERAL of these geared mechanisms in his truck so that told me THIS HAPPENS A LOT. Good luck.
Aug 13, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
91 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
