Question about Stanley Bostitch MIIIFN Flooring Nailers
I rented a bostitch MIIIFN to install bamboo hardwood flooring. The nailer is splitting the tongue of the wood. Is there some type of adjustment that I can do to stop the splitting?
  • 700 Answers
You do not use nails to install bamboo floor! EVER!
bamboo flooring is installed on glue alone, and then some weight is put on the top to keep it down while glue is binding. this usually takes about 12 to 24h, depending on climate, temperature and humidity.
if these are standard board, they are 6' long and between 4" and 6" wide, depending on manufacturer. all ends indexed (tongue and grove) and pre-finished.
bamboo is a grass, but because of glue used in it's construction (formaldehyde) it makes it very hard, even harder than ironbark, in jenkins scale, bamboo floorboards are between 13 and 15 (pine is about 4.5, oak about 10 in this same scale)
bamboo expand as well with humidity, and you need to leave 10mm free space along the walls to allow for that expansion. this space is normally convered by skirting. skirting is usually about 19mm thick, therefore gap between 10mm and 15mm is ok.
if running board is longer than 13m, you need to leave expansion joint on it as well.
if you are installing directly on the concrete, do not forget about moisture barrier, if this is on already existing wood floor or cork, moisture barrier is not necessary, but you need to remove old paint from subfloor (sand it to "bare" wood) to allow better glue adhesion.
if you are installing bamboo over the bearers, then use some sort of subfloor and glue bamboo on the top of it. you cannot just stick bamboo to the bearers, bamboo is too thin (15mm) for that
NEVER NAIL BAMBOO FLOOR!
you use glue and sparringly pin-nails on bamboo skirtboard (even pin-nail tend to explode them...).
i hope that this short explanation will help you, it will be better actually if you ask some professional floor shop in your area how to do that...
if you are happy with my advice, please do not hesitate to leave your comments or vote (or both...) for me, thanx!
Posted on Aug 03, 2010
I rented a Bostitch Floor Nailer from Home Depot, and the nails wont set into the maple flooring. Iv used three different compressors(all set to 90psi) and 4 different Bostitch Nail Guns. Im going out of...
Ive had the same problem where it was putting divits you could see from the staples, we ended up changing out the flooring completely. Only thing besides trying diff psi's to get it perfect and different length staples/different heads on staples(nails) , maybe try staple gun. Keep trying every woods different, odd that it started half way through job.. odd.
Jul 15, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
I have just gotten an MIIIfn. Which base plates do I use for 3/4" hardwood and how do I assemle them?
The white urethane plate at the bottom of the shoe is held on by 3 metric allen head screws.The one that comes on the tool from the factory is the one for the 3/4" flooring. Here is a link to the parts diagram with the part numbers.
http://servicenet.dewalt.com/Products/Detail?productNumber=MIIIFS
Jun 19, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Can i use 1 and 1/2 inch nails to nail 3/4 inch hardwood.
The only time you would use 1 1/2" nails for 3/4" wood is if the flooring is being place on plywood over concrete.
Dec 05, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
How do i change the o rings on bostitch MIII hardwood nailer?
after you buy the o ring kit, then remove the cap screws. remove all the orings from the firing valve and cylinder, then replace cap and screws,, very important please grease the new orings before trying to put gun back together, you can get a schematic and o ring kit from toolpartsdirect.com
Nov 22, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
May 02, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
5/8 flooring nailer
the base plate may be shimmed, but that unit was designed for 1/2" and 3/4" however, the Bostitch MFN201 Manual Flooring Cleat Nailer Kit will install 1/2"- 5/8" & 3/4"
Feb 17, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Bostitch Flooring Stapler is making dents
Is the flooring a solid wood flooring or is it an engineered? Is the stapler an MIIIFS or a SX150 or a LHF97125? If its solid then its a square edge board nad it its not centered on the flooring properly it will dent the ens.
Feb 15, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch MIIIFN Flooring Nailers Logo
386 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
