Question about Canon Cameras
My camera pc1060 turns on well but the lens cant detect anything, so no picture/image in the lcd. help....help....hlp.....
I've come across this situation, where the aperture stays closed. The lens cover opens, but the shutter is in the closed position preventing light from hitting the sensor element. The problem was the flexible circuit board (ribbon like cable) entering into the lens assembly. The camera has to be dismantled so that the lens assembly can be freed, then opened. There are two magnetic solenoids that operate the shutter. The fault was that like repeadedly bending a metal rod, it eventiually weakens and breaks. This happened to the ribbon cable. I replaced it with very fine wire, 4 strands in all. Came back good as new once reassembled.
Posted on Oct 06, 2010
I cannot see anything on my camera screen is blank other than the camera info. i cannot see what i what to snap or record. and i cannot see even pictures that have been snapped bofore the problem occured....
There is a ring on the back of your camera toggle it up or down
I think you information is on if not turn your camera off
then turn it back on take the lens cap off take another picture
problem solved
May 07, 2014 | Nikon Coolpix S2700 16 Megapixel Compact...
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
How do I get it to work? I have a Nikon D40x and have just bought a macro extension tube.When I turn on the camera it says that no lens is attached. I have a 18-55mm lens attached at the end of the tube...
Turn the mode dial to M for Manual. You'll lose all through-the-lens metering capability, so you'll have to review your pictures or else use another light meter.
Jun 18, 2010 | Nikon D40x Digital Camera
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
Every thing works but cant see anything threw camera lens cover is open i see all menu options but no pic it records sound but no video any help TIA
Seems your camera Sony DSC-T1 got bad ccd imager problem, as camera does not show live image to record and shows previously stored pictures fine in playback mode.
Sony will repair it free of cost. Click Sony CCD Imager Support for details.
Jun 21, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
New Kodak M1033 cannot see image on LCD in sunlight
This is a common problem with all LCD screens without anti-reflective coatings.This is normal. Increase the brightness of LCD while shooting in the sun. Internal memory normally takes only a few images. This is normal. Use a memory card to shoot more images.
Feb 10, 2009 | Kodak EasyShare M1033 Digital Camera
Protax DC500T Digital Camera lens won't open
It will need repairing.
Thanks,
Lee
Jun 17, 2008 | Cameras
Lcd screen
Cannot get images deleted
Feb 23, 2008 | HP PhotoSmart M437 Digital Camera
I see nothing in the Viewfinder...
The camera has a mirror lock up feature for cleaning the CCD sensor. You may have engaged it. Check your manual about this function
Dec 27, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Cameras Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
