Question about Vacuums
How do I restore my devices firmware for my zune 30gb
  • 2,272 Answers
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 03, 2010
Is it a power failure or is the TNPA5335 board faulty?
As there is LED blinks, the power board is funtioning; and 5V rail is OK. The start-up voltage, that have to come from the main board doesn't. Check for the reason. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
In most cases, the main board might have to be replaced. If so, a firmware update too might be necessary.
Jul 08, 2014 | Panasonic Test Tool Part Tzsc09187
How do i remove code E48d d2 code on cei slot machine
see the next step:
1) Start the computer or laptop and then login as an admin.
2) Click the Start button then select All Programs, Accessories, Tools, then select System Restore.
3) Inside the new window, click "Restore my system to an earlier time" then press Next.
4) Select the most recent restore date from the "select a restoration point" listing, then click Next.
5) Then click 'Next' within the confirmation window.
6) Reboot your machine whenever the restoration is finished.
Jun 28, 2012 | Vacuums
No suction. model # 4495, bagless upright.
Mine wasn't picking up stuff either. After unplugging the unit, I had to take the yellow top off--unscrew the two screws that are hiding in the 4 indentations on either side. After removing that "hood" I then carefully lifted up the left side of the roller to free it of the belt. A middle piece came out too, which I carefully set aside with the screws. Then I had to clean that whole roller--including prying off the ends and cleaning the debris out of everwhere--so gross.
Then I restored the caps to the roller, threaded the roller back through the belt, turned the roller to make sure the belt was in straight alignment, put that middle piece back, restored the yellow hood, affixed it with the two screws, plugged the whole machine in, turned it on, readjusted the height, and voila!
Check your manual too. If its a gonner I used http://homeappliance.manualsonline.com/manuals/mfg/eureka/4490_series.html as a reference.
Aug 29, 2011 | Eureka 4495A Bagless Upright Vacuum
It is not picking up the dog hair and hoses are clear can i check where the roller is? how?lanye59@gmail.com
Apr 06, 2011 | Eureka Vacuums
I'm new in the line of using Archos. I was trying to register it when it indicate a new update available. I did ACCEPT to download the update. Now my Archos 5 is not coming up. Can you please help with...
Hi,to solve your problem please follow the instructions .
Hold down the volume button and the power button for several seconds the ARCHOS goes into a restore type mode.
connect the archos to your computer with the usb cable .next copy and paste the downlaoded firmware .aos file onto the aarchos device .
your archos device will be detected as a mobile device in windows explorer.double-click on the device to see its "internal hard driver.open this internal hard driver icon and you will see the various archos folder inside..paste the update file into this area but be careful not to paste it into any of folders there.
the device will recognize the new update file and invite you to install it.Follow the on-screen instructions.
To download the firmware navigate to this link click HERE
To the firmware ..select your product ..and then click on Download Archos 5 Internet Tablet OS v 2.0.38 (92054Kb) .
Save it to your desktop .
Dec 26, 2010 | Vacuums
I have an ipod touch and i forgot my password and now i dont know how to unlock it :(
There are other, more technical, ways to do it, but if you don't know what you're doing you'll break your ipod so I'll stick to the safe and easy official method:-
Connect your ipod to your host pc and run the itunes software. Click on the "restore" button (in some versions of the software it's labelled "reset to factory settings"); this will reset your ipod to the way it was when you first got it out of the box. You'll then have to re-sync all of your music back onto the device and if you have a jailbroken model you'll have to reapply the jailbreak.
If you want to see the alternative methods, then just search "ipod touch password reset". Some of them claim to reset the password only without having to start all over again but some owners report that their machines simply don't work afterwards.
Hope this has helped you, please take a brief moment to rate my reply.
Sep 06, 2010 | Vacuums
My dyson dc08 has a loss of suction. A flap valve operates within a few seconds of startup which appears to divert air. I have replaced both the hepa and sponge filters but the problem persists. If there...
You have used your Dyson too long without thorough cleaning - Here's how.
Obtain a torx screwdriver, or a set of torx bits, you will need to select the correct size when you come to remove the screws. They are all the same, so you will need only one.
Take the radix catridge off the machine as if to empty the clear plastic sucking container. (From here on your hands get dirty).
Firmly pull out the inner conical funnel. Here it is removed. (Note I am showing photos of the cleaned device).
Next remove the three torx screws. You can see the recesses these are hiding in in the above picture they are the holes without nozzles. The screws are self tappers screwed into plastic, and are easy to undo.
Remove the lower part of the housing and its rubber sealing ring.
Note the orientation for when you put it back together. The above photo shows the lower bell housing opened away from the top part as if opening a door. It's pretty hard to put them together incorrectly so don't worry too much.
You now need to remove two further screws which are recessed into the sides of the inside of the housing. Their positions are easy to find as they are the only recesses large enough, and match up with two curves on the outside of the housing. They are at the left and right in this picture.
Next you need to remove the handle at the top of the radix housing that you normally use to pick up the device.
Remove the two screws deep in the tubular holes you can see at the right of this picture.
Then slightly lift the end of the handle at the end where you removed the screws.
Next use a screw driver to push the other end of the handle off the housing away from the end where you just removed the screws.
This picture shows the handle pushed out (or ready to be re-attached)
Finally remove the screw revealed by removal of the handle.
You can now lift off the top housing revealing the wormy looking cyclone device This is where most of the **** builds up.. Lift this off and clean everything out thoroughly with water.
Make sure everything is clean and dry!!!!
Re-assemble in reverse order.
Now your Dysin is restored to original sucking power.
May 19, 2010 | Dyson DC08 Cylinder Bagless Canister...
Sir, I have TDK 4 GB Pendrive. I was formated some
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
Dec 14, 2009 | Vacuums
Power
Hi Zulydia,
does that version has the "restore" red button in the upper side?
If yes, when you push it, the engine showld work for litle time only (restoring), then the rest is normal. If not, the engine can be clogged, wich needs to be opened and cleaned (tuff operation but easy). Normally it happens when the engine has a overheat.
Dec 01, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
307 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
