Question about MTX Thunder 1501D Car Audio Amplifier
What is the long volume/bass control"s proper name.
The long volume control mostly used for bass to turn up and down....need to know the proper name for it and where you can buy another one. thanks
  • 70 Answers
The Control you are talking about is an External Bass Control also known as EBC knob you can probably find one at MTX.com or crutchfield.com or any authorized MTX dealer. Please vote and leave high marks. Thank you
Posted on Aug 03, 2010
Pyle PPHP159WMU: Just received this used unit and the bass speaker tends to cut out the louder the volume is set. Does the battery have to be fully charged for the unit to function properly?
The speaker may have a current sensing device to avoid damage under high volume conditions. Also check the setting of your bass control. Every 3 db increase in setting doubles the power going to the driver and it is easy to over drive the unit at high volumes if your bass control is not on flat.
Feb 03, 2016 | Pyle Audio Players & Recorders
My amp turns on good but after a while of too much bass causes a ugly sound too loud what could it be? Can it be repaired?
If you have over driven the amp by playing it real loud with the bass control turned up, it is very possible that you have toasted the output stages of amp.
Every time you boost a tone control by 3 db you have doubled the output power at that frequency. So if you are "coasting" along at a nominal 75 watts, the moment you boost the bass by 3 db the amp has to put out 150 watts at that low frequency.. Go to +6db and now the poor amp has to kick out 300 watts! And so on.
Rule of thumb - you never use your tone controls at very loud levels. Tone controls are there to compensate for the poor frequency response of the human ear at low volume levels - the Fletcher Munsen effect. At low volumes our hearing with the lows and high frequencies so when you play something at low volume you boost up the bass and treble to compensate for poor hearing. At loud volumes our ears respond properly.
Sep 12, 2015 | Car Audio & Video
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I hav a Silvertone sslb11 bass that needs a new volume pot and don't know wich one to buy. I don't see any part numbers or values printed on the pot. Does anyone know part numbers, brand, or...
I recommend checking music stores in your area for that, it doesn't have to be any specific rating of impedence. Depending on brand, I see guitars with anything from 50 ohms to 250 ohms. This only allows a faster cutoff on volume than others. The most critical action is to have a smooth taper, meaning a straight volume rise or decline versus one that goes down slowly or quickly and suddenly cuts off. Most any guitar volume control from a music store will work just fine. In case I confused you, ohms is the rating of the control, the taper or smoothness is classed as A, B, or C. A is normally for volume controls and B is used mostly for tone controls. Knowing that should give you insight insight to the difference of the controls.
Mar 31, 2013 | Music
I NEED TO KNOW HOW TO USE THE FOUR CONTROLS AT THE BODY OF THE WASHBURN FORCE 4 ACTIVE BASS
two of the controls are volume, two are tone, (at least usually). the best way to use the controls is to try one at a time till you find the combination that pleases you most. I have been playing bass for 40 years and have 7 bass guitars, two with active pickups and two that acoustic electric
Mar 17, 2011 | Washburn Force 4 4-String Electric Bass...
Bass and Treble controls
Use Z-enhancer to select custom (you may have to hold it down for 2 secs)
A-M button then selects or bass treble settings.
volume up/down changes the setting
May 19, 2010 | Clarion XMD3
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
I don't know how to use custom eq
press the EQ button until it says custom on the seting then press the tuner select button left or right and it will say bass or treble use the volume to turn it up or down then u got the bass control.:)
Feb 14, 2008 | RCA RS2652 Shelf System
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
MTX Thunder 1501D Car Audio Amplifier Logo
113 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
