Question about Bosch Classixx WFL 2066 Front Load Washer
The magnetic valve is not working /the water does not shut off
The magnetic valve is not working.
The water does not shut off during the cycle when it is supposed to.
The water runs continuously (even during the last spin cycle - when it should not be running at all).
I need a new magnetic value but my washing machine is very old and I cannot find the model number anywhere on line.
The model number for my Bosch Washer is: WFA086Q
Another model number that is a similar washer is: WFL2260GB/01
If you have any suggestions I would appreciate hearing from you.
Thank you.
    Genius:
  • 1,075 Answers
Go to the makers web site bosch this is a very common fault and this valve is out there at about 7 dollers/6pounds i buy them every day.adrian,,,,,
Posted on Aug 03, 2010
During the dry cycle, it seems as if water is continuing to be added. A few times i minute, at least 5 cups of water is pumped out into the drain. This continues for the 3 hr dry cycle. When done the...
could be one of your water solonoid valves is leaking by, where hot and cold hoses hook up in back, they get energized when calling for water then shut down when fill level is reached, some valves have filter in it, both valves come apart and can be cleaned, make sure no debri is caught in valves to prevent from closing fully
Oct 18, 2013 | Washing Machines
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Water does not enter dishwasher during wash cycle
Make sure the under-sink valve is turned on. Then suspect the water solenoid valve under the front may have an open coil or stuck shut valve.
Dec 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Washer will not fill with cold water during cycle
it sounds like your mixture valve is faulty on the cold water side. that is the valve where you screw the hose ends on. it needs to be replaced you can purchase one at your local sears, be sure to take your make and model number with you
Dec 31, 2008 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
144 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
