Question about Graco Digital Deluxe Imonitor Baby Monitor
Red light and beeping as if its not charged but green charge light turns on when i charge it. no sound from babys room
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Posted on Sep 14, 2010
  • 1 more comment
  • freeclimb Jul 13, 2011
    Thank you!! Our monitor had the same problem and i fixed it with your instructions in 30 seconds!!!!! Thanks so much!!!
  • Richard Gambill
    Richard Gambill Nov 19, 2011
    Ditto the thanks! Solution worked perfectly for a unit with red AND green lights on and no sound.
  • Danny Kearse
    Danny Kearse Sep 11, 2012
    thank you very much that worked but I already bought a new one
I have tomy classic baby monitor from a year now, from few days parent unit is beeping continiously, have checked connection and evrything and even the green light does goes red
The unit may have a back-up battery installed that is low on charge. Replace the back-up battery. The unit is probably still working because you have it plugged-in.
Sep 17, 2014 | Baby Gear
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
My baby monitor won't charge - it's not even recognizing the charger as plugged in -- the red light doesn't go on any more??
shut it down and restart and see if it takes the charger ..usually there is nothing that makes the camera behave that way but the charger ..either being damaged or the plug does not makes contact well ..check the wire not to be damaged and try another charger with the same specs ..exactly the same ..It is possible to be damaged if you let it in the plug for a long time ..
If it shows out that the charger is not to blame ..than it is a mater of plug need to be changed cause is damaged ..In worse case just open it and hot wire if you can not get a plug to match ..
Dec 28, 2011 | Samsung Wireless Baby Monitor Camera...
My Angelcare monitor was working fine for 1 month. Then I went to unplug it to move my crib to another room, went to plug it in and now it makes a weird constent beeping noise?? What is wrong with it the 2...
Without inspecting this item it is impossible to diagnose the problem. If the product is under 12 months old please return it to your retailer with proof of purchase.
Sep 10, 2011 | Angelcare Deluxe Movement Sensor & Sound...
I just bought a second hand baby monitor from graco and they have charged but the one on my room is flashing a red light and continuosly beeps why???
When mine is red I check two things, that it's sitting flat in the charger and that all plug ins on all units are in snugly. The other thing is sometimes the main unit in the babys room is turned off so make sure the switch on the side is on. Hope it helps.
Jan 26, 2011 | Graco Imonitor Digital Baby Monitor
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
Graco baby monitor just keeps chirping and blinking red. Don't' have owner's manual. Is it needing to charge or what is going on?
Try this. Your hand held unit may not be communicating with the one in the room.
If the Parent Unit is unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down
both the Parent Unit and the Nursery Unit. Wait for 10 seconds and hold the volume down button on the Parent Unit while pressing the On/Off switch until you hear a beep. When the unit powers up, release the volume down switch and within 5 seconds press and hold the volume down switch again for at least 2 seconds. All of the Sound Light LEDs should illuminate and the bottom LED will be red.
I hope this helps.
Apr 10, 2009 | Baby Gear
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Feb 17, 2009 | Samsung Cameras
Graco Digital Deluxe Imonitor Baby Monitor Logo
1,438 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
