Question about Honeywell HW628 Window Mount Fan
I have a honeywell window exhaust/fan. How do I take it apart to clean it?
3 Suggested Answers
SOURCE: i have a honeywell fan
I have a fan from them as well...you can't take it apart. Isn't that stupid?
Posted on May 26, 2008
SOURCE: I owna honeywell commercial grade
The front wire grating has hooks all around the edge that latch onto the rear grating. You need at least two screwdrivers, blades or thin & stiff shims to pry half the hooks off. Do this by inserting your shims between the front and rear grates, on either side of a hook. Then, lever your shims such that the rear grate warps enough to free a hook and let it pass in front. (Note: this IS difficult; the first hook will not want to clear the rear grate. It helps to have an extra pair of hands, and/or another object to temporarily keep the first hook seperated. It may also be possible to start with three shims and clear two hooks in the beginning). Continue clearing the hooks in a consecutive fashion (they're progressively easier) until half of them are off, at which point the front grate should come off using a little muscle. A couple notes: if available, a plastic shim is preferable over a metal one because it shouldn't damage the nice finish as much (alternatively, wrap your shims in cloth). It is NOT necessary to remove the whole fan cage from the stand to do this. Expect the reverse process to be equivalently challenging. Please wear safety glasses in case your shim breaks or slips. Lastly, good luck if you try to lubricate the shaft. I've tried multiple substances, but day-long blowing continually dries out the lubricant.
Posted on Jul 30, 2008
How to find a window fan that can be taken apart to be cleaned
I use this kind as a window fan and it’s great and easy to clean. Very inexpensive too.
Nov 16, 2017 | Miscellaneous
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
Fan has become noisy. Does the fan need to be cleaned? Can I take it apart to vacuum the inside?
if the fan is noisy it can be two dirt or grit affecting the propeller or the baring on the motor shaft
Aug 23, 2009 | Honeywell Dryers
Cleaning Honeywell table fan
By the way please check my video on YouTube for your answer. Watch, Subcribe, Share, and Comment!
Thank you
" How to Open a Honeywell Fan to Clean" on YouTube
Jun 14, 2009 | Honeywell HT-800 Table Fan
I can not figure out how to take the cover off of the fan so I can clean it.
I have the same 1 , I take mine outside and hose it out , dont spray the switch so much and let it dry very well before plugging back in.
Phil
Jan 12, 2009 | Honeywell HT-800 Table Fan
Loud screeching sound from window fan.
There are two bearings in most motors.  One is at the base of the fan blade where the shaft goes into the motor.  Try lubricating this with a small amount of household oil.  If your lucky, this will stop the problem.  If not, the bearings have worn and the unit will need replacing.
Nov 15, 2008 | Honeywell HW628 Window Mount Fan
Honeywell HW628 Window Mount Fan Logo
44 people viewed this question
Top Honeywell Dryers Experts
Rob Sinbad
Rob Sinbad
Jay Finke
Jay Finke
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
