Question about Iomega (33654) Limited Edition 500 GB USB Hard Drive
I have an Iomega 500GB USB 2.0 Desktop Hard Drive. I am running Mac OS X. I can't seem to restore any of my files (even recent ones). Any suggestions?
  • jwagner8 Aug 03, 2010
    Thank you - this fix helped and I got my data back.
    Genius:
  • 1,035 Answers
Hi. You need to use special software on how to ercover your files. Please click here.
Have a good one!
Posted on Aug 03, 2010
I recently restored to factory settings on my HP laptop.once restored I then input my Iomega drive into the USB port to access some of my saved files.
Just to be on the safe side, why not plug in your iomega drive into another known working computer and see what happens. If it works fine and is properly recognized then the anomaly lies within the software of your laptop.
U might want to contact HP - but be fore warned that they are terrible for support if your unit is "out of warranty." If that is the case I would simply google the anomaly and in all likelihood you will get links that will help you fix it yourself.
Apr 06, 2015 | Iomega Usb 500Gb 3.5 Desktop Select...
I want to use in my mac osx mac book pro
Hi Carmen; just plug it in to your system's USB port and format it for use with a mac os according to the provided instructions.
According to the manufacturer: Mac:
  • Built-in USB
  • Mac OS X 10.4 - 10.6
  • 128MB RAM
  • Drive must be reformatted for use with Mac (instructions included)
Mar 19, 2015 | Iomega 500GB Prestige USB 3.0 Portable...
I don't know how to select the type of partition needed for my mac when I am formatting the drive for mac OS?
1 - Place the drive on the desktop.
2 - Start the "Disk Utility." Click on the drive, then on the "Erase" button.
3 - Select the "MS-DOS File System" in "Volume Format."
4 - Provide a new name for the drive. Click the "Erase" button.
5 - Perform the instructions given on the screen and finish the formatting.
Apr 02, 2011 | Bernoulli Iomega Prestige Portable hard...
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 28, 2010 | Iomega 500GB eGo BlackBelt Portable 34621...
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega 500GB data corrupted
The boot info is bad. If there is info that is needed you will have to use a recovery program like getdataback fat 32 and getdatabackntfs
Aug 02, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
I have a 500GB hard drive that I am using with a Mac OS X 10.5. I have been working with iMovie file that are several GB in size and I can't save them onto my iOmega hard drive. I have tried starting a new...
First of all I would check what the file system is on your iOmega drive. If it is FAT32, then it will be unable to handle any files over 4GB in size.
If necessary, reformat it to a Mac friendly file system and retry.
If this doesn't help, please repost your problem including the exact text of any erro messages that you receive.
Hope this helps!
Jun 29, 2009 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
Iomega
Yes. The MiniMax is designed to match the MacMini from Apple and comes formatted out of the box to work with a Mac. (One of the few drives that is!)
I think Iomega supply various Windows drivers on the CD
Apr 09, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
External drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
May 14, 2008 | Iomega 33089 250 GB Hard Drive
Iomega (33654) Limited Edition 500 GB USB Hard Drive Logo
23 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
