Question about Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
Delta 13022 - Hot water out of the shower is much cooloer than out of the sink faucet. How is the mix of hot & cold controlled?
    Scholar:
  • 67 Answers
The Delta shower has a rotational limit stop designed so that when another fixture is activated, such as a toilet or dishwaser, the water does not go to extreme hot or cold. The reason for this is that the Delta shower unit is not pressure balanced or does not contain an anti scald device. The pdf document below will show how to adjust the water tempature if you feel it is too cold. Please use caution as it is probably set the way it is to prevent scalding.
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevH_4.15_15e05.pdf
Posted on Aug 03, 2010
Kitchen delta faucet doesn't get hot enough
Was it hot enough before the Delta? If so open and close the hot water valve (under the sink) several times as there maybe mineral deposits. I know you said the flow is the same on hot and cold but unless your version is a single handle model the problem should lie with the valve. If this is a cartridge model (cold & Hot together) then the cartridge may be out of align allowing the cold and hot water to mix.
Jan 18, 2018 | Delta & Single Handle Shower Faucet
I have two vanities and a shower in the bathroom. We only get hot water to the sinks when we turn on the shower to hot. Even if we turn off the shower we will still get hot water for a while. It just seems...
Check the water supply lines to the shower at the faucet handles. If the fitting for the hot water line connected to the handle is loose, it can twist and kink off the water supply further down the line when you turn the faucet handle. I'm not exactly sure how this could be relevant otherwise, but under normal design circumstances this type of scenario with your shower wouldn't matter for other faucets.
May 01, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Have hot water in the bathroom sink spigot, but the shower is the single handle and turned on all the way, water is not hot...too much cold mixing, How do you adjust it?
You need to take the handle off...ususally held on with a small allen screw on the bottom side of the handle. After removing the handle there should be a dial setting.
Feb 18, 2011 | Delta & Single Handle Shower Faucet
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
332 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
