Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Numark CDX CD Turntable
My CDX is doing nothing any more. Just all the lights are illuminated when I switch on the CDX. The CD drive is working a while and then it stops. And it don`t shows any reaktion when you press any button. It looks like a heavy problem in the software.
Is there any body out there who can help me?
greatings, Klaus
  • 2 more comments
  • sorce Jun 26, 2008
    same issue. its been to the shop twice
  • sfeeya Oct 14, 2008
  • Anonymous Feb 27, 2009
    My Numark CDX powers up and plays for about 20 minutes and then it freezes up. Non of the functions work and the song thats playing just gets stuck in one spot like a scratched record. I have to power it off and let it sit for about 15 minutes before it will power up again. Could you please help me?
  • hmz_y
    hmz_y Nov 01, 2012
    hi i have the same problem failed firmware update did you guys fix this i need help
I had the same problem, I had to constantly turn it on and off by pressing the power button really fast and now finally it works.
Posted on Apr 23, 2009
HERE YA GO!! GOOD OLD FASHIONED BEATING FIXED MINE... I PROMISE THIS. When you turn on your CDX... HIT THE SQUARE AREA where the play button and the cue buttons are located. It will jump to CDX on the screen and work fine. Mine did this and i messed around with bumping it and stuff and figured this out
Posted on Mar 31, 2009
I had this problem too... it went back to normal when i flicked the reverse switch
Posted on Sep 07, 2008
Have you found a solution. mine is doing the same thing.
Posted on Jun 26, 2008
The problem is over heating ,try cooling fans,it works for me.
Posted on May 05, 2009
How too conect numark cdx turntable to numark dm 1002mkII
All you have to do is to connect the 2 RCA audio line out from the CDX at any pair of the 4 line inputs (RCA too) at the 1200mk2. Keep in mind: Don't connect the CDX out at the PHONO inputs of the mixer.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 01, 2010 | Numark CDX Turntable
Numark CDX doesn't recognize any discs
You need a replacement CD drive. This is a common problem with this model. Im pretty sure they sell drives for $50-80. You could try removing and reinserting. 4 screws on front Casing, slides out straight.
digitalrepair@hotmail.com
Apr 21, 2010 | Numark CDX Turntable
I have the Numark CD Dj in A Box NDX200 and I'm getting a No
Did you try multiple discs? I would say the CD drive is defective. You should still be covered under warranty. Contact Numark for service repair.
Dec 25, 2009 | Numark CDX Turntable
My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Motor trouble cdx
What exactly is the problem with your numark cdx cd player ?
Regards.
uk/europe repairs link... http://www.audiovisualservices.info/
Dec 11, 2008 | Numark CDX Turntable
Numark CDX Search (for fast forward and rewind) not working.
Possible switch fault or servo problem,if you havent had it repaired you can send it to us.
Regards.
Nov 15, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
CDX wont read any CDs
The CD transport (reader) is shot. These units are known for this! To date, they still havent fully corrected the problem. A band-aid fix is to buy a new transport thru numark or parts dealer.
Apr 13, 2008 | Numark CDX Turntable
Cdx doesnt read any cd.....
Numark has yet fix this issue. You will need a replacement CD drive, they swap right out. Their warehouse is located in Cumberland RI (US). Unless you could score one on ebay. I have about 3 of them, you interested?
Mar 20, 2008 | Numark CDX Turntable
Not reading any cd's
they are known for this! Does it take cd in for a few seconds and spit out? Does it take cd in and just tick? (if you put ur ear up to the drive you'll actually hear it try to spin but just give a lil tick noise). Numark does sell a replacement cd drive which isnt exactly a 100% fix but worth a shot seeing how the unit cost quite a bit. If you do end up replacing the cd drive and does not fix your problem there is also an internal cable. Once you pull out the drive, look inside to the left you'll see a white flex cable which may need to be re-seated. Let me know how you make out!
~digitalscorpion
Jan 15, 2008 | Numark CDX Turntable
CD is stuck in the Numark CDX cd turntable
hello, there should 4 little black screws on the top of the cd tray when it is removed from the deck. two of them are on the rear top in black plastic. the other two are holding the silver plate down as well. remove those four screws. the top should slide off. after that is off, you should be able to see how the disc is being secured. careful not to pry any thing it should all come apart. good luck.
Nov 29, 2007 | Nu Mark Numark Cdx Table Top CD Player CD...
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
1,060 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
