Question about Whirlpool 24 in. DU900PCD Built-in Dishwasher
Hi there, I have a Whirlpool Quite Partner 1 dishwasher. It was working fine until today the water would not drain. I detached the drain hose and it was clean as a whistle. When I had the drain hose off I ran hot water and it was draining through clean. What else could it be? I have no idea how to fix this. Thanks.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherHi there, I have a - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 03, 2010
Whirlpool dishwasher, quiet partner 1. Does not drain, does not finish wash cycle.
ensure your dishwasher pump and drain hose are unobstructed. If your machine does not drain it will not refill with fresh rinse water and since it can't do that the cycle will never finish.
Many people don't completely rinse off food stuffs from their dishware, expecting the dishwasher to take care of it. To be honest, a dishwasher is more of a fine cleaning and disinfecting device than a pot scrubber. Because of this, grease, food debris, etc can clog the pump or drain line over time. be sure to use a good de-greasing agent regularly once the flow of water has been cleared (don't wash your dishes with it however)
Mar 20, 2015 | Whirlpool Dishwashers
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
My dishes are not clean in my whirlpool gold quite partner III. my model #gu2275xtvy0
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Whirlpool Dishwashers
Whirlpool Quite Partner III water is not draining.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 29, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water does not drain.
If this is your 1st dishwasher and you have a garbage disposal installed, quite possibly the dw inlet fitting on the disposal still has the knockout in place. Remove the dw drain hose from the disposal and check to see if the knockout has been removed.
Feb 08, 2010 | Whirlpool Gold 24" Tall Tub Built-In...
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Water remains in Whirpool Gold Quiet Partner dishwasher
sounds like an issue with the drain pump, disconnecting the drain hose fromm the trap and run the unit, pointing the disconnected drain hose into a bucket. You should get a fairly strong stream of water until most of the unit has drained, if not you either have a blockage or ,with the grinding sound, a bad pump.
Mar 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water Stayed in dishwasher
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU900PCD Built-in Dishwasher Logo
220 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
