Question about Sharp LC47SB57UT 47 in. TV
Hi, I have the sharp LC-47SB57UT 47" LCD. Just bought in March. Worked great and we love it, but all of a sudden when you press the power button on the remote or the tv itself. The indicator light on the tv turns from red to blue, but absolutely nothing else happens. No click, No Picture (not even a glow), no sound, and none of the on-screen options function. Acts and appears to still be off, but blue light indicates it's on. Any suggestions or solutions? Thanks!
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
satavlad
  • 405 Answers
SOURCE: Sharp tv doesn't turn on
Power supply/ invertor unit needs replacement.
Posted on Oct 23, 2009
  • 41 Answers
SOURCE: Sharp LC-37SB24U will not turn on
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
  • 321 Answers
SOURCE: Sharp LCD flashing red light and no picture
yes thats is a common problem for all flat tv not only
sharp ;/ first theres is capacitor in power supply
you probly have few one there blow up and it could bee from the power section of your back light circuit
a good technician can fix that easy
good luck
Posted on Apr 02, 2010
caroldon
  • 17130 Answers
SOURCE: Tv sometimes will not power
Possible that there are dry soldering joints in the TV main board or in the processor section. It will be good to remove and have a good visual check to determine , reconnect all connectors , re solder all the suspected dry/poor joints in the board.
Please find some tips for such related faults. TV malfunction
While you plug and unplug the board is being reset, so check the processor section, solder the microprocessor IC.
Posted on Nov 25, 2010
Won't power on
Have you checked all fuses (where fitted)?
Feb 18, 2014 | Sharp LC-47SB57UT 47" 1080p LCD TV - 16:9...
I HAVE SOUND IN MY LC42D62U NO PICTURE
I had a TV guy to come and hang my Sharp LC-65SE94U I bought it in March 2009. The TV guy broke it. How much is my tv worth? Thank you for your time. pammie10@comcast.net
Jul 11, 2012 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No power to HDTV
Call for repair, the set is under warranty.
Feb 19, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC47SB57UT 47 in. TV Logo
141 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
