Question about Refrigerators
The food in the refrigerator is freezing - Refrigerators
    Genius:
  • 1,075 Answers
The drain plug is blocked ,at the back you will find a little hole use a old type pipe cleaner and unblock.adrian,,,,
Posted on Aug 03, 2010
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Food is freezing in refrigerator
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 14, 2011 | Maytag Refrigerators
The fridgerator keep freezing the food. it is on the lowest setting but still it freezed the food. whirlpool MODEL: ET18NMXAW03 SERIAL: ED3042768 have had someone tell me to clear the food so that it...
heatman101
Jan 25, 2011 | Whirlpool Refrigerators
Suddenly the refrigerator is freezing everything we have not changed the settings we tried to even turn down and is still freezing the food.Help!
heatman101
Jan 04, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchenaid side by side freezes food in the refrigerator side
The damper between fridge and freezer is most likely stuck open.
Oct 02, 2017 | KitchenAid (KSRD22FKST) Side by Side...
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
