Question about Select Brands BL-220 Stand Mixer
I HAVE A SELECT BRANDS STAND MIXER MODEL STM-09BL AND NEED TO FIND A NEW ROTATING STAND FOR IT. CONTACTED COMPANY AND THEY DONT STOCK THE PART ANYMORE. WHERE CAN I FIND ONE
Need a new bowl
Sadly FIXYA has no control or ability to FIX the problem you have with the mixing bowls you ordered that are not the correct configuration for your mixer. suggest you contact the manufacturer again
Aug 17, 2017 | Oster Stand Mixer model: Fpstsm5102
This is missing the manual and the hook for kneeding bread. I would like to download a manual. Is there a part number for the kneeding hook?
Need your exact model number from the bottom and back of your stand mixer. You can enter the model number on this webpage to find out if the manufacturer has made a manual available on-line.
If there is no result contact customer support at 1-866-698-2538.
If this was a new purchase that should have contained the manual and hook I would encourage you to contact customer service or return to the vendor for replacement.
For available mixer attachments click on Stand Mixer Attachments & Categories here. (bottom left)
Jan 29, 2011 | KitchenAid KSM 500 325 Watts Stand Mixer
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Grinding noise when running.
It very likely sounds like a plastic gear that is worn. If this is the case, then a replacement is very likely stocked by the manufacturer only.
I advise opening the unit to identify which one you need, then 'phone the manufacturer with the make model and year of the product.
If they say they do not stock it - then I'm afraid that's as far as you can go with this.
Aug 16, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Apr 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Power On Problem
Check to see if the contact points on the control board are working. Adjust the screws at the top of the control board until the contacts make contact. That should fix your problem.
Feb 13, 2009 | KitchenAid KP2671 Professional 6 Series...
Hobart mixer model # D 300
I apologize but im unable to answer yours or any others at this time.Ive been hijacked by another user on this site that is dropping my rating.I contacted alex@fixya.com (manager) of this site about restoring my account but has yet to do so.If my request fall on deaf ears maybe if you can email1.gif him and explain that its hard to get info on any hobart products and im the only one that is a hobart tech answering questions for FREE!!As soon as this matters resolved i will continue to help people as ive been doing for a year on this site.
Apr 01, 2008 | Hobart D300 Stand Mixer
Replacement beaters
I called west bend about mixers for my stand mixer.Model number 41036. They said this model has been discontinued and they could not help at all!!!
Jan 19, 2008 | Food Mixers
Food Mixers Logo
Top Select Brands Food Mixers Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Are you a Select Brands Food Mixer Expert? Answer questions, earn points and help others
