Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have a Motortguide 54 lb thrust motor. It takes a KT 150-02 switch, which I thought was bad since my medium speeds 3 and 4 did not operate. It's not the switch, but it's the wiring functions in the bottom of the motor where the prop is located. There are two sets of wirings in lthe bottom, similar to a starter with the graphite brushes. One of the wiring configurations draws 6 volts and the other draws roughly 8.5. 8.5 is too much and it has, in some cases melted the solder of the copper wires which feeds my medium speeds 3 and 4. Motorguide has corrected the problem part, but I don't know how to install the part, nor do I know which ball of copper wires it is. Is it the prop side ball of copper or is it the back side wires? How do yhou install this part?
Where you buy this part the rotari switch.
Posted on Jan 17, 2011
Hampton bay Fan 54 in
How old is fan, and did you check to see if all screws are tight? If it was working before, then sounds like something happen either losing ground or motor ran hot or over heated. Does it make noises?
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Lost #1 and #2 speeds
Contacts inside switch may have become corroded.
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Only have fifth gear and second in reverse on my 54 pd thrust motor guide
my trolling motor has same problem, I replaced the (5) speed selector swith on the foot control and that solved nothing. I have the side selector switch (3 postiion) on order after testing with a meter
Apr 19, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
687 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
