Question about RCA D52W136D 52 in. TV/DVD Combo
We have rca scenium high def projection tv model # D52W136D. it is stuck in dvd mode and i cannot get it back into tv mode. the dvd player (built into the tv) has not worked for months, and today my son tried to have the dvd player open by just pressing the open button on the front panel of the tv. since then the tv won't go back in tv mode, the remote works to turn the tv on or off, but that's it. i have changed the remote batteries. i can't get any of the buttons on the front panel of the tv to work either, except the on button.
  • 2,335 Answers
It sounds like the open button has either been stuck in the 'pressed' position (examine it closely to see if a corner is stuck or if it still appears to return to it regular position when released) which you may be able to reseat by wiggling it while pressing it, or the switch (button) has been physically damaged so that even though the action allows it to 'pop up', the contacts inside remain in a closed state.
If the button is now damaged and not letting the TV's 'brains' know when any other button is pushed, there is not much you can do besides having it serviced and replacing parts until functionality is returned.
The one, free troubleshooting step you can try is to simply unplug the unit for 10 minutes or so.
For many electronic devices, a deep power-down will force a hard-reset of the brains inside. This can clear up erratic behavior on many devices. You dvd won't magically start working, but you may find that while your TV has lost all setup programming (channels, sources, etc), it ought to startup in TV mode at least rather than DVD mode.
I hope that helps.
Posted on Aug 03, 2010
My GE universal remote for RCA Scenium tv doesn't work the DVD part
If this is a combo unit (TV with DVD built in) you need the original remote---Universals almost always are missing key features the original remote had as most companies have someone else make the unit and put their name on it.
Mar 21, 2012 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium D52W136D Issues
Your set requires a qualified service technician to repair it. Sears repairs all major brands, regardless of where you purchased it. There are also many other repair facilities in your local area:
http://yellowpages.superpages.com/listings.jsp?C=tv+repair&L=Bel+Air+MD&MC=1&OO=1&F=1&CP=Computers+%26+Electronics%5EConsumer+Electronics%5ETelevisions%5EService+%26+Repair%5E
Dec 22, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W136D 52 in. TV/DVD Combo dvd does not play
did you try to get a dvd cleaner to clean out your dvd player.
Feb 13, 2010 | RCA D52W136D 52 in. TV/DVD Combo
I have an RCA D40W20 tv. I have the vcr/dvd connected to the video 1 jacks. picture will not format to screen. everyones heads are cut off. picture is too tall. any fix?
Ty using the zoom settings on the TV or the dvd player, also check the inputs by testing the tv with free to air or another input to determine if its the tv or the dvd player. Good Luck.
Nov 27, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium D34W1350 with built in DVD player cannot reconize a DVD after it is inserted into place. Help me with this.
The DVD unit probably needs to be replaced. I am not sure you will be able to obtain one or if you will have to go through a RCA Auth. Repair Facility. The DVD units are not difficult to replace if you can get one.
Sorry I am not able to help more.
Skyassoc
Jun 22, 2009 | RCA Scenium D34W20 34" TV
RCA SCENIUM MODEL # D52W136DBYX1
If it's normal television, with CRT picture tube . then it's Blue gun which went off normally its a solid state circuit which can malfunction. which is located at the back neck of picture tube blue gun out put circuit a transistor or a resistance of 470 K or 390 K Ohms can blow off. or the tube base can loose contact with the blue gun pin.
Feb 06, 2018 | RCA D52W136D 52 in. TV/DVD Combo
TV RCA SCENIUM D52W136D 52in
Problem solved, it was my green driver this time and only $25 to replace.
Jan 16, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Integrated DVD player
If your handy, then try to disassemble the DVD .player from the unit and manualy clean the lens assy,but please be aware of the HI Voltage dangers inside of a tV set. if your not then Please call a pro top assist you with this repair. If the units not worth fixing then simply buy and inexpensive DVD player/recorder and hook it up via the external inputs. Good Luck
Jul 24, 2006 | RCA Scenium D40W20 40" Rear Projection...
RCA D52W136D 52 in. TV/DVD Combo Logo
200 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
