Samsung syncmaster p2370hd My monitor's settings got messed up somehow and the screen is all blue. No matter which settings I put the RBG colors on, it doesn't change the screen color. I have all of the color effect settings turned off, so it isn't that. I've tried tweeking every setting that I can find with no change. Is there someway to restore it to factory settings or is the monitor just broken?
MicrowaveSvc
  • 9098 Answers
SOURCE: monitor color changed
Assuming you can rule out the PC and the cable (are the pins ok?) then it sounds like it needs component-level electrical troubleshooting.
Posted on Jan 12, 2007
  • 3 Answers
SOURCE: DVDs Play in Black and White
is it a uk dvd in a uk dvd player and not a copy? if so is your tv and dvd both set to PAL or PALi mode? check both one of the two may be in NTSE mode this would cause it to be Black and White OR it could be your scart cable (it wil be a pal/ntse problem) (
Posted on Feb 14, 2007
lukster
  • 217 Answers
SOURCE: on screen display on monitor locked and need to restore factory settings
Hold the menu button down long enough and it should unlock, if it unlocks and then locks back up immediately, you have a problem on the main board
Posted on Mar 17, 2007
  • 59 Answers
SOURCE: VERTICAL LINES AND THE COLOR CHANGES
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
Posted on Oct 22, 2007
  • 1694 Answers
SOURCE: Toshiba MW27FPX dropped it!
See if you can borrow a TV de-magnetizer (degauss) from a tv shop...if that doesn't purify the color, then the shadow mask inside the picture tube is bad = no repair unless CRT is replaced
and that would cost more than a new TV ! ...................T.
Posted on Jan 31, 2008
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
My monitor icon get yellow. i wan all in real colors
the problem is with your display cable move the cable connected to the cpu up and down if the color changes the problem is with the cable if there is no variation try a pci or agp graphics card or check the monitor with other computer if still you have the same problem the problem is with your monitor some components in the rbg section in the monitor is fried even the IC which controls the rbg section can be fried
Dec 15, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
After startup on Sammsung SyncMaster 940 N I do not see
Sounds like system software needs to be replaced... re-installed. It probably got corrupted somehow since it is not rebooting properly. Use the original discs that came with the computer. Thnx
Jul 24, 2010 | Samsung SyncMaster 940N (Silver) LCD...
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
My monitor's color is mixed with the color yellow
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Jul 21, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Televison & Video Logo
298 people viewed this question
Top Televison & Video Experts
