Question about Acer Aspire One Netbook 8.9" Notebook
It won't shut off. I have tried the start button (suppose?to start and shut off BUT it doesn't .
  • 4 Answers
The setting referred to in the Power Options from the control panel should work
If all else fails the press the power button for 10 secs will
Posted on Aug 07, 2010
    Scholar:
  • 121 Answers
Not sure if you are talking about the Power button or the start button on Windows. If you are talking about the Power button then there is a setting in Power options that are settable by the user to perform a certain task when buttons are pushed. I would start there. If you are talking about the start button and select Turn Off computer then there is probably a service or back ground application that is not stopping thereby extending the power down sequence, but when this happens you usually get a window that states that some application is closing and you can either wait for it to end itself or force it to end. If that is the case, note which application is hanging up and if it is not one you need uninstall it. Hope this helps.
Posted on Aug 03, 2010
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Dell Inspiron 8500 won't shut down, on/off button doesn't repond
Hold down the ON/OFF button for several seconds until it shuts off.
Mar 04, 2013 | Dell Inspiron 8500 Notebook
Door won't open
You must have popped the door rod off.
Mar 03, 2018 | 1996 Chevrolet Suburban
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
Front right side hit . replaced concerter and won't crank over /or start fuel pump doesn'd even come on when key is on ?
ricks63toy, I believe that Ford still uses what is called an inertia switch even in the hybrids. This switch will shut off in the event of an accident shutting off the fuel pump. This is a safety feature built into the vehicle. Seeing that this is a newer vehicle I trust that you still have the manual. If not, the switches are usually located in the trunk. Look on the side walls of the trunk and see if you can locate it. It is usually marked by a sticker. When you find the switch, push the red button down until you hear a click. This will reset the switch and allow power back to your fuel pump. Good luck with this.
May 17, 2011 | 2010 Ford Fusion Hybrid
My mp3 from time to time would shut off or the screen would go black and won't shut off.
Same problem I had awhile back, make sure you don't have a memory card inside the player when you turn it on. It boots up in an incorrect order and doesn't start. To turn it off when it's stuck in that position I believe I held the sliding power button to "On" for 15 seconds.
May 10, 2011 | SanDisk Fuze MP3 Player
Shut down
Go to the control panel select power option and check the settings.
Mar 30, 2010 | E-Machines eMachines Desktop PC
Acer Aspire One Netbook 8.9" Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
