Question about Philips 42PF7220A 42 in. Plasma Television
Powwer tv will not turn on
    Sniper:
  • 63 Answers
Do you have a blinking LED with no OSD-on screen display?
Best Regards
Posted on Aug 03, 2010
  • Erik Pettersen
    Erik Pettersen Apr 06, 2011
    I have this same issue as the original poster... black screen with 7 blinks of the red led light. any suggestions?
Tv will not turn on
its the power pack in the tv that has gone out...contact the manufacturer for either the part to replace it your self or for a technician to repair it.
Nov 14, 2007 | Toshiba TP50H50 50" Rear Projection...
I have a Model TC32LX70 Serial MX72540116. I also have Verizon Cable. The TV set keeps going off and I have to manually turn it back on. Sometimes it will go off and cannot be turned back on but will...
Hello
If the power indicator is blinking on the front of the VIERA, turn off the TV and unplug all HDMI cables that are connected to the TV. Then unplug the power cable from the current power source. Try a different electrical outlet. Remove the power cable from the rear of the TV and plug it back it in (the power cable tab is inserted correctly when you hear a click).
Just unplug the tV from AC powwer wall socket, let it be at theis state for about 30 minutes, replugh the TV only, and check whether the fault rectifes. OK.
Apr 23, 2011 | Panasonic Televison & Video
The other day when you go to turn the tv on it takes about 2to3 min. for the picture to come on. But yesterday a new problem started now when you try to turn it on the green powwer light comes on then...
Your problem definitely relates to the Capacitors on the power board.
Common and WIDESPREAD issue that Samsung refuses to acknowledge.
The capacitors bulge and may leak fluid, they require replacing with higher voltage caps. Call a service tech if you are uncomfortable with replacing them yourself.
If that fails, you will have to replace the entire power board, they are available on the net for approx $100.
Good Luck
Nov 30, 2009 | Televison & Video
My TV worked fine this morning,Turned it off,Went back to put it on and now it won't turn on at all,Why?
Maybe faulty power switch or its blown a fuse or the powwer supply inside the TV is kaput.
If its out of warranty get in touch with a reputable TV mechanic and ask them to come and repair it. It might be good to get a ballpark figure on how much it's going to cost.
Good Luck
Sep 13, 2009 | Sanyo DS35510 35" TV
Samsung PN42A450 Plasma TV Won't turn on....
Powwer Board or Y-Main problem.
need to replace after check.
Jan 23, 2009 | Samsung PN42A450 Plasma TV
No sound
replace the eprom with program replace audio out put ic check powwer of ic
Aug 12, 2008 | Philips 27PT5445 27" TV
No powwer
did you check the fuse?the str,and the horizontal output transistor?try to check them because they were the cause of no power.
Nov 07, 2007 | Toshiba 24 24 in. TV/VCR/DVD Combo
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
405 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
